Retrieve Unique Values from feature layers
18994
11
05-07-2015 11:08 AM
RyanSmith1
Hi Guys, i need to retrieve unique values from a set of feature layers. I've been using the following example as a guideline - Using JavaScript to populate a ComboBox with unique values | ArcGIS Blog but my problem as noted in that article is that the records i have is over 500, 2500 to be exact. I came across a certain "returnDistinctValues" property from the Query API Reference - Query | API Reference | ArcGIS API for JavaScript which if set to true will return distinct Values of the specified outfields of the query. I haven't tried out as yet since it requires "supportsAdvancedQueries" property of the feature layer to be set to true and the current configuration has it set to false.
I do recognize that changing the maxRecord of the feature layer could severely hamper the performance, so the only other option i can think of using the queryIds method of the feature layer?
Please advise as to which approach i should take to overcome this issue.
Ryan
RyanSmith1
Thanks guys!
I really appreciate your help on this topic. I've merged both approaches into one solution for my application.
Thanks again
Regards,
Ryan
DougBrowning
MVP Esteemed Contributor
Anyone have any ideas on how to do this in the ArcMap query builder.  Say I want to set a definition query on a Feature Service - if I click Get Unique values I can not get a full list due to it being a FS.  Seems like ArcMap does not use a distinct call.
thanks
