Reopen popup with updated attributes
1447
05-24-2024 12:38 AM
WoHouYeng
I have been following this sample to create an popup with edit actions. However when I try to reopen the popup upon successful edits, the popup content is still showing the old value. I used the below code to reopen the popup.
layer.on("edits", e => {
    view.openPopup({
        features: e.updatedFeatures
    editor.viewModel.cancelWorkflow();
JoelBennett
MVP Regular Contributor
We have something like the code below in our framework, and it works for this purpose:
//This is typically used when the popup's selected feature's attributes have changed, and the popup needs to reflect the new values
function reshowPopup(popup, graphic) {
	if (popup.selectedFeature == graphic) {
		var selectedFeatureIndex = popup.selectedFeatureIndex;
		var features = popup.features.concat([]);
		popup.features = features;
		popup.selectedFeatureIndex = selectedFeatureIndex;
JoelBennett
WoHouYeng
Hi @JoelBennett , sorry for the late reply. I managed to reopen the popup with the updated attributes with your solution after commenting the fetchFeatures property from the openPopup method. Thanks.
reactiveUtils.when(
              () => editor.viewModel.state === "ready",
                // Remove the editor and open the popup again
                view.ui.remove(editor);
                view.openPopup({
                  fetchFeatures: true,
                  shouldFocus: true
