Hello @AlexCopli ,
Thanks for finding this bug. We are working to get a fix in for this real soon. Version 4.20 is not affected by this issue, however, we are trying to get a patch for this as soon as we can.
Thank you,
Jose
@JoseBanuelos, Is version 4.21 affected by this issue? Is there a current workaround?
@AlexCopli
Looks like the problem is on version 4.21 as well.
@JoseBanuelos
Can you please let us know if there is an ESRI recommended workaround for this issue? A vast majority of the data I work on is in the pacific ocean.
We are working on a patch right now, so no workaround will be needed for 4.21. I will post once the fix is in.
Jose
@AlexCopli
What version did you find this issue in? This was reproduced only in 4.21. We are trying to get a patch for 4.21. If you reproduced in an earlier version, can you send repro app and repro steps?
This issue has been patched and no longer reproducible in version 4.21. You can test with the following sample:
https://developers.arcgis.com/javascript/latest/sample-code/sandbox/?sample=sketch-geometries
Please let me know if you are still seeing this problem.
Jose
