renderer for graphicslayer not working?
3358
02-07-2014 08:09 AM
EvanBossett
I am trying to add a renderer to a graphicslayer.  My graphics layer shows up fine and i can control the symbology manually (If i change the symbol color, it changes,etc.)
However, if i create a renderer and add it to the layer, the "default" symbology is still retained.
Please help.
Thank you.
//CODE
symbol1 = new esri.symbol.SimpleFillSymbol().setColor(new dojo.Color([255, 0, 0,0.5]))
gl = new esri.layers.GraphicsLayer();
var attr = {"MY_VALUE":5}
gl.add(
         new esri.Graphic(
         new esri.geometry.Point(-75.03810508573053, 40.26871269474917),
         symbolX,
         attr
map.addLayer(gl);
renderer1 = new esri.renderer.ClassBreaksRenderer(symbol1, "MY_VALUE");
renderer1.addBreak(0,3,new esri.symbol.SimpleFillSymbol().setColor(new dojo.Color([255, 0, 0,0.5])));
renderer1.addBreak(4,7,new esri.symbol.SimpleFillSymbol().setColor(new dojo.Color([0, 255, 0,0.5])));
renderer1.addBreak(8,Infinity,new esri.symbol.SimpleFillSymbol().setColor(new dojo.Color([0,0,255,0.5])));
gl.setRenderer(renderer1)
TyroneLigon
If I'm reading this correctly, you want to use the renderer symbology but the symbol you're adding to the graphic is what's being drawn. If that's the case, try using 'null' as your symbol value in the graphic constructor.
TyroneLigon
EvanBossett
I appreciate the prompt response.
You understand my problem correctly.
however, it is worse
graphics drawn using the following show up (but do not have a renderer) :
map.graphics.add(g);
however, my graphicslayer is not showing up (even when I remove the renderer).
I did include code:
gl.visible=true;
any help would be appreciated.
thank you.
AllenHuang
if you look at the API
https://developers.arcgis.com/javascript/latest/api-reference/esri-layers-GraphicsLayer.html#methods...
There is no renderer parameter for GraphicsLayer. You would have to control each symbol in your GraphicsLayer separately.
