Relative URLs in Popup Content
3847
11
08-16-2021 07:14 AM
DeniseDemone1
I'm in the process of upgrading an ArcGIS Javascript API 3.x application to 4.19/20 and having trouble with URLs in my popup.
In 3.x, I was able to set the template content like so, using relative paths to my reports:
 var templateContent = "<b>{STATIONNUM} (" + status + ")</b><hr>" +
                        "<b>Station Name: </b>{STATIONNAM}<br>" +
                        "<b>Description: </b>{DESCRIPT}<br><br>" +
                        "<a href='Station/StationReport/{STATIONNUM}' target='_blank'>Full Station Report</a><br><br>" +
                        "<a href='StationFiles/Files/{STATIONNUM}' target='_blank'>Sketches / Photos</a><br><br>" +
                        "<a href='https://maps.google.com/maps?q=&layer=c&cbll=" + data[0].latitude + "," + data[0].longitude + "' target='_blank'>Google Street View</a>" +
                        showSession + "<br/><br/>" + adoptionInfo;
This same code works in 4.x, except for the relative paths. I end up with this in the popup:
<div class="esri-feature-content">
	<div>
		<b>229327 (Intact)</b>
		<hr>
		<b>Station Name: </b>Minard Bog<br>
		<b>Description: </b> <br><br>
		<a href target="_blank">Full Station Report</a><br><br>
		<a href target="_blank">Sketches / Photos</a><br><br>
		<a href="https://maps.google.com/maps?q=&amp;layer=c&amp;cbll=44.12769707011916,-65.12424322455458" target="_blank">Google Street View</a><br><br>
		Not Adopted
	</div>
</div>
But, if I put in the full URL, it works properly:
                        "<a href='https://localhost:44322/Station/StationReport/{STATIONNUM}' target='_blank'>Full Station Report</a><br><br>" +
                        "<a href='https://localhost:44322/StationFiles/Files/{STATIONNUM}' target='_blank'>Sketches / Photos</a><br><br>" +
result:
	<div>
		<hr>
		<a href="https://localhost:44322/Station/StationReport/229327" target="_blank">Full Station Report</a><br><br>
		<a href="https://localhost:44322/StationFiles/Files/229327" target="_blank">Sketches / Photos</a><br><br>
		Not Adopted
	</div>
</div>
Seems like a bug me? Has anyone else experienced this?
LaurenBoyd
Hi all,
The HTML sanitizer may be stripping this out for security purposes depending on how you are creating the popup content. Have you tried formatting your Popup content using a function? Here's an example of how this would look with relative paths: https://codepen.io/laurenb14/pen/zYJqzYp
Lauren
JoePfeifer
Relative paths aren't working for me either; they just get stripped out.
ForrestLin
I just got same issue.
LaurenBoyd
Hi all,
Lauren
ForrestLin
Can I do the same for popup title? formatTitle?
LaurenBoyd
Yes, the PopupTemplate.title property also accepts a function.
Lauren
ForrestLin
What parameter does the function of PopupTemplate.title property take? event?
ForrestLin
How to pass parameters to function formatContent()?
LaurenBoyd
What parameters are you trying to pass into the function? The formatContent function in my example above allows you to access the current selected feature as a parameter and then you can use the graphic property to access the attributes.
function formatContent(feature) {
    // Access the feature's graphic which holds the attributes.
    // If needing the attributes, be sure to set "outFields=['*']" on
    // the layer or on the popupTemplate.
    console.log(feature.graphic.attributes);
    const mainDiv = document.createElement("div");
    const element = document.createElement("a");
    element.href = "./test.html";
    element.target = "_blank";
    element.innerHTML = "This works now!";
    mainDiv.appendChild(element);
    return mainDiv;
Lauren
ForrestLin
Is function formatContent able to pass other parameters?
