ReferenceError: declare is not defined
7262
5
04-23-2013 01:40 PM
AaronConnolly
I'm trying to write my first DOJO class and re-use it within a very simple application, however I can't figure out why the `declare` method in DOJO is not defined?
Here is my DOJO class code in a separate file: mapManager.js
// CLASS
// mapManager
require(['dojo/_base/declare'], function(declare){      delcare("mapManager", null,   {   sourceMapNode: null,   maxZoomResolution: 10,    constructor: function(params){       this.params = params || {}; // Returns a object literal if undefined       // specifiy class defaults    this.sourceMapNode = params.sourceMapNode;    this.maxZoomResolution = params.maxZoomResolution;        // Hook up map movement events    alert("Hooking up map move events!");   }  }); });
Here is the index page that sets up the ESRI SDK, includes my special class and attempts to instantiate it.
<!DOCTYPE html> <html>   <head>     <meta http-equiv="Content-Type" content="text/html; charset=utf-8">     <meta http-equiv="X-UA-Compatible" content="IE=7, IE=9, IE=10">     <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"/>     <title>Simple Map</title>     <link rel="stylesheet" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.4/js/dojo/dijit/themes/claro/claro.css">     <link rel="stylesheet" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.4/js/esri/css/esri.css">     <style>       html, body, #map {         height:100%;         width:100%;         margin:0;         padding:0;       }       body {         background-color:#FFF;         overflow:hidden;         font-family:"Trebuchet MS";       }     </style>     <script src="http://serverapi.arcgisonline.com/jsapi/arcgis/3.4/"></script>     <script src="script/class/mapManager.js"></script>     <script>              dojo.require("mapManager");          function init() {                          var parameters = {                 sourceMapNode : "map",                 mapZoomResolution: 12                         };                        // Give map to map manager             var mapManager = new omega.mapManager(parameters);                      }                    dojo.ready(init);            </script> </head> <body class="claro">     <div id="map"></div> </body> </html>
In Firebug the first error I see is:
ReferenceError: delcare is not defined
[Break On This Error]
The second error I see is a 404 error:
"NetworkError: 404 Not Found - http://serverapi.arcgisonline.com/jsapi/arcgis/3.4/js/dojo/mapManager.js"
Two questions:
1. What am I doing wrong? I have followed tutorials on DOJO's website and this should be working. Of course I have missed something important, I'm sure.
2. Why is custom class mapManager.js assumed to be a part of the DOJO library provided by ESRI? The second error indicates that the page "thinks" mapManager.js is part of the ESRI library when infact it's available locally.
derekswingley1
Bunch of things...
You had "delcare" instead of "declare" in your code.
Use define instead of require in mapManager.js and return the result from declare like so:
define([   "dojo/_base/declare" ], function(   declare ) {    return declare("omega.mapManager", null, {
Tell Dojo where mapManager is via dojoConfig.packages. Something like this:
    <script>       var dojoConfig = {         packages: [{           name: "omega",           location: location.pathname.replace(/\/[^/]+$/, "")         }]       }     </script>
If you're curious about that location.pathname part, read up on using custom modules from a CDN hosted version of Dojo (it's a quick read). Since Dojo knows where to find mapManager, do not include it with a script tag.
Finally, since you're creating an AMD module, load it with require instead of the (legacy) dojo.require.
Here's a working example:  http://dl.dropboxusercontent.com/u/2654618/simple-class/index.html
And here's a direct link to mapManager:  http://dl.dropboxusercontent.com/u/2654618/simple-class/mapManager.js
derekswingley1
Bunch of things...
AaronConnolly
Bunch of things...
define([
], function(
  declare
    <script>
      var dojoConfig = {
        packages: [{
    </script>
Thanks, Derek. That spelling error is shameful. I appreciate the links.
derekswingley1
You're welcome...definitely the thing where a second set of eyes helps. Hope you find the additional info helpful as well.
AaronConnolly
Indeed. One question, why in the mapManager.js do you not provide a class name with the declare? How does DOJO "know" that the omega.mapManager is the class defined there in /mapManager.js? Is the file name important as well?
AaronConnolly
Nevermind. I just read from the DOJO guide:
"Class names can still be explicitly created using the first argument passed to define, but this is optional. If define is not passed a string as the first argument, the module identifier will be built using the module's path and file name."
