Overlay KML Network link of a Fusion Table
1629
5
02-02-2012 09:47 AM
DaleSimper
I am wondering if it is possible to overlay a KML network link of a fusion table using the javascript api.  I got the overlay working using the flex api by just using https://www.google.com/fusiontables/exporttable?query=select+col1+from+2817988+&o=kmllink&g=col1 for the KML layer. Any help and examples would be much appreciated, thanks.
derekswingley1
It works if you replace the plus signs in the URL to the KML file with spaces:  http://jsfiddle.net/uyAuW/
derekswingley1
If a URL points to a KML file, you should be able to pass it to the KMLLayer class to create a layer from the KML. See the simple KML Layer sample for an example.
DaleSimper
Yeah, that's what I was using, but it doesn't seem to work. I can get it to work using the KMLLayer class using the Flex API and according to this thread
http://forums.arcgis.com/threads/40348-Display-layer-based-on-Google-Fusion-Tables it works with silverlight. So I was just wondering if anyone has had success using the API for Javascript.
derekswingley1
DaleSimper
Thanks Derek, I figured it had to be something simple.
JohnGravois
just an fyi, i tested this in 3.4 and found that a '+' is now acceptable, while a space is not...
http://jsfiddle.net/C5mdZ/
