Real World Sizing of CIMSymbol
1245
05-26-2022 02:43 PM
JesseKHall
I've been unable to display a CIMSymbol with real-world dimensions in a scene view. Can anybody offer any assistance? Here is a sample of code to test with. I am using useRealWorldSymbolSizes, but it doesn't seem to be working.
As I zoom in on the map, I'd expect the icon to appear larger as it's overall dimensions remain the same, but it's scaling "normally", which isn't the desired behaviour here.
<!DOCTYPE html>
<html>
  <head>
    <meta charset="utf-8" />
    <meta
      name="viewport"
      content="initial-scale=1,maximum-scale=1,user-scalable=no"
    <title>
      Testing 3D Vessel
    </title>
    <link
      rel="stylesheet"
      href="https://js.arcgis.com/4.23/esri/themes/light/main.css"
    <script src="https://js.arcgis.com/4.23/"></script>
    <style>
      html,
      body,
      #viewDiv {
        padding: 0;
        margin: 0;
        height: 100%;
        width: 100%;
    </style>
    <script>
      require([
        "esri/Map",
        "esri/Basemap",
        "esri/Graphic",
        "esri/geometry/Mesh",
        "esri/geometry/Point",
        "esri/views/SceneView",
        "esri/layers/FeatureLayer",
        "esri/widgets/Legend",
        "esri/renderers/Renderer",
		"esri/symbols/CIMSymbol",
		"esri/symbols/support/cimSymbolUtils"
        Map,
        Basemap,
        Graphic,
        Mesh,
        Point,
        SceneView,
        FeatureLayer,
        Legend,
        Renderer,
		CIMSymbol,
		cimSymbolUtils
        let startingPoint = new Point({
          type: "point", // autocasts as new Point()
          x: -90,
          y: 30
		const vesselBeam = 100;
		const vesselLength = 250;
		const vesselSymbol = new CIMSymbol({
		  data: {
			type: "CIMSymbolReference",
			symbol: {
			  type: "CIMPointSymbol",
			  useRealWorldSymbolSizes: true,
			  symbolLayers: [
				  type: "CIMVectorMarker",
				  enable: true,
				  anchorPointUnits: "Relative",
				  billboardMode3D: "None",
				  frame: {
					xmin: 0,
					ymin: 0,
					xmax: vesselBeam,
					ymax: vesselLength
				  markerGraphics: [
					  type: "CIMMarkerGraphic",
					  geometry: {
						rings: [[[0,0],[0,vesselLength*0.8],[vesselBeam/2,vesselLength],[vesselBeam,vesselLength*0.8],[vesselBeam,0],[0,0]]]
					  symbol: {
						type: "CIMPolygonSymbol",
						symbolLayers: [
							type: "CIMSolidStroke",
							enable: true,
							width: 8,
							color: [0,0,0,255]
							type: "CIMSolidFill",
							enable: true,
							color: [51,51,51,255]
				  scaleSymbolsProportionally: true
        const map = new Map({
          basemap: "hybrid"
        const view = new SceneView({
          container: "viewDiv",
          map: map,
          center: [-90, 30],
          zoom: 17
        let features = [
		  geometry: startingPoint,
		   attributes: {
			 ObjectID: 1
		// geometryType and spatialReference of the layer
		// will be inferred from the first feature in the array
		// if it has a geometry.
		let layer = new FeatureLayer({
		  source: features,  // autocast as a Collection of new Graphic()
		  objectIdField: "ObjectID",
		  renderer: {
			type: "simple",
			symbol: vesselSymbol
		map.add(layer);
         view.on("click", function(event) {
          // Get the coordinates of the click on the view
          var lat = event.mapPoint.latitude;
          var lon = event.mapPoint.longitude;
          newPoint = new Point({
            x: lon,
            y: lat
		  let editFeatures = [
			  geometry: newPoint,
			   attributes: {
				 ObjectID: 1
		  let edits = {
			updateFeatures: editFeatures
		  layer.applyEdits(edits).then(function(results) {
          view.goTo(newPoint);
    </script>
  </head>
  <body>
    <div id="viewDiv"></div>
  </body>
</html>
ArnoFiva
Our 2D symbology showing flat icons, lines or CIM as you are using do not support real world sizes unfortunately. We would recommend using volumetric 3D symbology such as ObjectSymbol3DLayer or WebStyleSymbols that also provide out of the box models for vessels.
Note that you can combine multiple layers of ObjectSymbol3DLayer primitives in a single point symbol to potentially create more complex, real world sized symbology.
