reactiveUtils.watch() on a custom class?
2032
03-25-2025 01:37 PM
fdeters
I'm starting to lean more on `reactiveUtils.watch()` for reactivity that isn't easily handled by my JavaScript framework. Generally, things are going well, but I'm running into an issue with unit/integration tests:
A common issue is that I will want to stub or mock a JS SDK class. For example, I frequently create a fake WebMap with fake layers:
class FakeLayer {
  constructor({ id, listMode, visible, type }) {
    this.id = id;
    this.listMode = listMode;
    this.visible = visible;
    this.type = type;
  when = async () => true;
const fakeWebMap = {
    allLayers: [
      new FakeLayer({
        listMode: 'hide',
        visible: true,
      new FakeLayer({
        listMode: 'hide',
        visible: false,
      new FakeLayer({
        listMode: 'show',
        visible: true,
My problem is this: reactiveUtils.watch() does not seem to work on POJOs or custom classes like FakeLayer above.
In the example above, I might be testing code that watches the `visible` property on each FakeLayer and mutates `listMode` if `visible` changes. How can I implement a mock/stub testing class that works with reactiveUtils.watch()?
JoelBennett
MVP Regular Contributor
JoelBennett
Have you considered extending the Accessor class?  See also https://developers.arcgis.com/javascript/latest/implementing-accessor/
fdeters
This looks like exactly the starting point I was looking for, thanks. I'll come back and accept as solution once I've seen if it works for what I need.
JoelBennett
Did this end up working out, or did you find something else more suitable?
fdeters
Actually, yes! I just got it to work moments ago. I used this section of the article you linked: https://developers.arcgis.com/javascript/latest/implementing-accessor/#define-a-simple-property
Here's what my solution looks like for setting up a single property that I can use reactiveUtils.watch() on:
const MyCustomClass = Accessor.createSubclass({
  constructor: function () {
    this.myProperty = null;
  properties: {
    myProperty: {},
I wanted to use native classes, but neither of the following were working for me (I'm not using TypeScript):
// native class using the @property decorator
class MyCustomClass extends Accessor {
  @property
  state = null;
// native class, no decorators
  constructor() {
    super(...arguments);
    this.myProperty= null;
  properties = {
    myProperty: {},
