Questions on Search Widget
3922
09-02-2015 10:51 AM
jamesa
Hello All,
I try to use search widget to find street intersection and here are my two jsfiddle files but I am not sure why the first code with define locator is not showing up the correct intersection point.
Please try this streets:
e state st & n 5th st, redlands ca
1. jsfiddle
http://jsfiddle.net/sky12/L8c035rg/1/
2. jsfiddle - Esri default
http://jsfiddle.net/sky12/0pod8chb/
Besides that, can you tell me how to show the "score" information on poup infowindow as well.
Thanks.
Drew
I think its because your marker symbol has an offset set.
esri.symbol.PictureMarkerSymbol("images/mylocation5.png", 17, 32).setOffset(18, 27)
remove the setOffset and it should hit the same location.
Drew
thejuskambi
The symbol has some kind of offset on it so it is showing at that offset distance.
Drew
Drew
jamesa
Thanks.  It works!  How about show "Score" on popup infowindow?
JssrRR
James,
Here, I added an infoTemplate with Score :
<!DOCTYPE html>
<html dir="ltr">
<head>
   <meta http-equiv="Content-Type" content="text/html; charset=utf-8">
   <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no" />
   <title>ArcGIS API for JavaScript | Basic Search</title>
   <link rel="stylesheet" href="http://js.arcgis.com/3.14/dijit/themes/claro/claro.css">
   <link rel="stylesheet" href="http://js.arcgis.com/3.14/esri/css/esri.css">
   <style>
      html,
      body,
      #map {
         height: 100%;
         width: 100%;
         margin: 0;
         padding: 0;
      #search {
         display: block;
         position: absolute;
         z-index: 2;
         top: 20px;
         left: 74px;
   </style>
   <script src="http://js.arcgis.com/3.14/"></script>
   <script>
      require([
        "esri/map",
        "esri/dijit/Search",
        "esri/InfoTemplate",
  "esri/geometry/Extent",
  "esri/tasks/locator",
  "dojo/dom",
        "dojo/domReady!"
      ], function (Map, Search,InfoTemplate, Extent, Locator, dom) {
  var map = new Map("map", {
          basemap: "topo",
          center: [-117.19, 34.055],
          zoom: 18
  //Create extent to limit search
         var extent = new Extent({
            "spatialReference": {
               "wkid": 102100
            "xmin": -13063280,
            "xmax": -13033928,
            "ymin": 4028345,
            "ymax": 4042715
  var search = new Search({
   enableButtonMode: false,
   enableLabel: false,
   enableInfoWindow: true,
   autoComplete: true,
   autoNavigate: true,
   map: map,
   sources:
  locator: new Locator("http://geocode.arcgis.com/arcgis/rest/services/World/GeocodeServer"),
  singleLineFieldName: "SingleLine",
  outFields: ["score"],
  localSearchOptions: {
   minScale: 300000,
   distance: 50000
  placeholder: "Search Place or Address",
  searchExtent: extent,
  highlightSymbol: new esri.symbol.PictureMarkerSymbol("images/mylocation5.png", 17, 32).setOffset(18, 27),
             infoTemplate: new InfoTemplate("Search Result: ${Score}")
  }, "search");
  search.startup();
   </script>
</head>
<body>
   <div id="search"></div>
   <div id="map"></div>
</body>
</html>
See this example;
Search using a suggestion template | ArcGIS API for JavaScript
