Question?
2371
11-22-2014 12:38 PM
MilerDouglas
I wrote the following code and everything run ok!
function manualPickAddress(evt){
map.graphics.clear();
var point = new Point(evt.mapPoint.x,evt.mapPoint.y,new SpatialReference({ wkid:2100 }));
window.alert(point.x+ ' ' + point.y);
var symbol = new SimpleMarkerSymbol().setStyle(SimpleMarkerSymbol.STYLE_SQUARE).setColor(new Color([255,0,0,0.5]));
var graphic = new Graphic(point,symbol);
graphic.setAttributes( {"XCoord":evt.mapPoint.x,"YCoord":evt.mapPoint.y,"Name":'Information'} );
map.graphics.add(graphic);
map.infoWindow.setTitle("Information");
map.infoWindow.setContent("Longtitude:" + evt.mapPoint.x+'<br />'+"Latitude:"+evt.mapPoint.y);
map.infoWindow.show(point);
The problem is that when I pick Athens Greece the long, lat, I take is not perfect or map constructor.
I want to make a map to inititalize and point to Athens Greece.
What should I do?
What values are evt.mapPoint.x and evt.mapPoint.y?
The event is click on the map.
