Question?
2429
11-21-2014 10:57 AM
MilerDouglas
      require([
        "esri/map",
        "esri/dijit/Geocoder",
        "esri/graphic",
        "esri/symbols/SimpleMarkerSymbol",
        "esri/geometry/screenUtils",
         "esri/geometry/Point",
  "esri/SpatialReference",
         "esri/InfoTemplate",
        "dojo/dom",
        "dojo/dom-construct",
        "dojo/query",
        "dojo/_base/Color",
       "dojo/domReady!"
      ], function(
        Map, Geocoder, Graphic, SimpleMarkerSymbol, screenUtils,
  Point,SpatialReference, Infotemplate, dom, domConstruct, query, Color
        // create a map and instance of the geocoder widget here
        var map = new Map("map", {
          basemap: "streets",
          center: [ -100, 40 ],
          zoom: 10
        var geocoder =  new Geocoder({
          arcgisGeocoder: {
            placeholder: "Find a place"
          autoComplete: true,
          map: map
        }, dom.byId("search"));
        map.on("load", enableSpotlight);
        map.on("click",manualPickAddress);
        geocoder.on("select", showLocation);
        geocoder.on("clear", removeSpotlight);
        function showLocation(evt) {
          map.graphics.clear();
          var point = evt.result.feature.geometry;
   //window.alert(point);
          var symbol = new SimpleMarkerSymbol().setStyle(
            SimpleMarkerSymbol.STYLE_SQUARE).setColor(
            new Color([255,0,0,0.5])
          var graphic = new Graphic(point, symbol);
          map.graphics.add(graphic);
          map.infoWindow.setTitle("Search Result");
          map.infoWindow.setContent(evt.result.name);
          map.infoWindow.show(evt.result.feature.geometry);
          var spotlight = map.on("extent-change", function(extentChange) {
            var geom = screenUtils.toScreenGeometry(map.extent, map.width, map.height, extentChange.extent);
            var width = geom.xmax - geom.xmin;
            var height = geom.ymin - geom.ymax;
            var max = height;
            if ( width > height ) {
                max = width;
            var margin = '-' + Math.floor(max/2) + 'px 0 0 -' + Math.floor(max/2) + 'px';
            query(".spotlight").addClass("spotlight-active").style({
              width: max + "px",
              height: max + "px",
              margin: margin
            spotlight.remove();
        function enableSpotlight() {
          var html = "<div id='spotlight' class='spotlight'></div>"
          domConstruct.place(html, dom.byId("map_container"), "first");
        function removeSpotlight() {
          query(".spotlight").removeClass("spotlight-active");
          map.infoWindow.hide();
  function manualPickAddress(evt){
   //window.alert(evt.x+' ' +evt.y);
   //var point = evt.mapPoint;
   //var point = new Point( {"x": evt.x, "y": evt.y, "spatialReference": {"wkid": 4326 } });
   var point = new Point([evt.x,evt.y],new SpatialReference({ wkid:4326 }));
          window.alert(point.x+ ' ' + point.y);
  // window.alert(point);
  var attributes = {"Xcoord":evt.mapPoint.x,"Ycoord":evt.mapPoint.y};
          var infoTemplate = new InfoTemplate("Latitude: ${Ycoord} <br/>    Longitude: ${Xcoord} ");
          var graphic = new Graphic(point,symbol,attributes,infoTemplate);
         // var graphic = new Graphic(point,symbol);
          map.infoWindow.setContent(evt.x+'<br />'+evt.y);
   //window.alert(evt.x+ ' '+evt.y);
            var max = height;
                max = width;
              width: max + "px",
              height: max + "px",
              margin: margin
            spotlight.remove();
When I manually pick an address the manualPickAddress() run
Point works ok but no graphic display (symbol) on the screen.
Any suggestion?
MilerDouglas
Fixed it.
