Question: Recursion is used in Java to reverse an array.
1486
01-17-2023 12:37 AM
hectorsalamanca
I'm just getting started with recursion, and while studying this article, I was able to utilise it to construct a basic factorial programme without any difficulty. I'm now attempting to construct a recursive function that writes an array in reverse order, but I'm not sure what I'm doing wrong. What am I overlooking? Thank you very much.
import java.io.*;
public class Recursion {
  public static void main(String[] args) throws IOException{
    int myArray[] = {1,2,3,4,5,6,7,8,9,10};
  public static void reverseDisplay(int[] ary, int position){
    if(position > 0)
      System.out.print(ary[position]);
     reverseDisplay(ary, position - 1);
Tags (1)
JohannesLindner
  1. You're not calling the function in your main
  2. You get an infinite recursive loop, because you keep calling the function even if position < 0
import java.io.*;
    reverseDisplay(myArray, 9);
    if(position > 0) {
Have a great day!
Johannes
JohannesLindner
import java.io.*;
    if(position > 0) {
Have a great day!
Johannes
