QueryTask DataGrid and Table
4380
03-30-2015 07:18 AM
AbelLudba
Hello
I am new to ArcGIS JavaScript.
I'm using ArcGIS 10 and would like to publish results of a simple Query in a table.
This is my Code:
  1. <!DOCTYPE html>
  2. <html>
  3.   <head>
  4.     <meta charset="utf-8">
  5.     <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no">
  6.     <title>Test QueryTask with Table</title>
  7.
  8.
  9.     <link rel="stylesheet" href="http://js.arcgis.com/3.13/dijit/themes/tundra/tundra.css">
  10.     <link rel="stylesheet" href="http://js.arcgis.com/3.13/esri/css/esri.css">
  11.     <style>
  12.       html, body { height: 100%; width: 100%; margin: 0; padding: 0; }
  13.     </style>
  14.
  15.
  16.     <script src="http://js.arcgis.com/3.13/"></script>
  17.     <script>
  18.    var queryTaskTwo, queryTWO;
  19.         var grid, store;
  20.
  21.       require([
  22.         "dojo/parser",
  23.         "esri/tasks/query",
  24.   "esri/tasks/QueryTask",
  25.   "dijit/registry",
  26.         "dojo/_base/array",
  27.         "dojo/dom",
  28.         "dojo/on",
  29.         "dojo/_base/connect",
  30.         "dojox/grid/DataGrid",
  31.         "dojo/data/ItemFileReadStore",
  32.         "dijit/form/Button",
  33.         "dijit/layout/BorderContainer",
  34.         "dijit/layout/ContentPane",
  35.         "dojo/domReady!"
  36.       ],
  37.    function (parser, Query, QueryTask, registry, arrayUtils, dom, on, DataGrid, ItemFileReadStore) {
  38.       parser.parse();
  39.
  40.       queryTaskTwo=new QueryTask("http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Demographics/ESRI_Census_USA/MapServer/5")
  41.    queryTWO=new Query();
  42.    queryTWO.returnGeometry=false
  43.    queryTWO.outFields=["STATE_NAME","POP00_SQMI","HOUSEHOLDS","BLACK","MALES"];
  44.
  45.
  46.         on(dom.byId("execute"), "click", execute);
  47.
  48.
  49.         function execute ()
  50.   {
  51.
  52.    queryTWO.text = dom.byId("stateName").value;
  53.           queryTaskTwo.execute(queryTWO,showResultsTwo );
  54.   //
  55.         }
  56.
  57.   function showResultsTwo(resultsTwo) {
  58.           //create array of attributes
  59.           var items = arrayUtils.map(resultsTwo, function (result)
  60.    {
  61.
  62.             return result.feature.attributes;
  63.           });
  64.
  65.
  66.           //Create data object to be used in store
  67.           var data = {
  68.             identifier : "SQMI", //This field needs to have unique values
  69.             label : "SQMI", //Name field for display. Not pertinent to a grid but may be used elsewhere.
  70.             items : items
  71.           };
  72.
  73.
  74.           //Create data store and bind to grid.
  75.           store = new ItemFileReadStore({
  76.             data : data
  77.           });
  78.
  79.           var grid = dom.byId("grid");
  80.           grid.setStore(store);
  81.      grid.setQuery({ SQMI: "*" });
  82.         // .................................................
  83.
  84.         }
  85.
  86.   //
  87.       });
  88.     </script>
  89.   </head>
  90.
  91.
  92.   <body class="tundra">
  93.     US state name :
  94.     <input type="text" id="stateName" value="California">
  95.     <input id="execute" type="button" value="Get Details">
  96.     <br />
  97.     <br />
  98.
  99.
  100.    <div data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'bottom'" style="height:150px;">
  101.      <table data-dojo-type="dojox/grid/DataGrid" data-dojo-id="grid"  id="grid" data-dojo-props="rowsPerPage:'5', rowSelector:'20px'">
  102.       <thead>
  103.         <tr>
  104.           <th field="SQMI"  width="10%">SQMI</th>
  105.           <th field="STATE_NAME" width="10%" >STATE_NAME1</th>
  106.           <th field="POP00_SQMI" width="30%" >SUB_REGION2</th>
  107.           <th field="HOUSEHOLDS" width="20%">AVG_SIZE97</th>
  108.           <th field="BLACK" width="10%">BLACK </th>
  109.           <th field="MALES" width="20%">OWNER_OCC</th>
  110.         </tr>
  111.       </thead>
  112.     </table>
  113.   </div>
  114.
  115. </html>
when I run this code, I get this error:
TypeError: undefined is not a function {stack: (...), message: "undefined is not a function"} "TypeError: undefined is not a function     at showResultsTwo (http://localhost/Dgrid/queryMultipleTest2.html:74:16
I could not find what am I doing wrong?
Would it be possible to help?
Thanks
Abel
KenBuja
MVP Esteemed Contributor
This is a duplicate of this question.
