Querying FeatureService behaves differently depending on MapView Zoom Level
1278
01-10-2023 05:16 AM
DavidHanimann
There is a strange behaviour when querying a FeatureService. I have a Point FeatureLayer that is hosted on ArcGIS Portal in a MapView. When the zoom level in the MapView is initially set to a high number (e. g.10), then  the points from the FeatureLayer are queried by the extent of the MapView, which is what I expect. However, when the initial zoom level of the map is at around 3 or lower or unset, then all points are loaded at once using queries with the parameters resultOffset and resultRecordCount. This happens regardless of the current zoom level of the MapView .The layer has a scel-dependent visibility and is only visible when zooming in. The layer has 100'000s of points, i don't ever want to load all the points.
Here an example of the behaviour: CodePen
Is there a way to cinfuger the loading behaviour? I couldn't find any doumentation on this behaviour, this would be very helpful.
JoelBennett
MVP Regular Contributor
Although there is no documentation I know of regarding this, you can "opt out" of this behavior.  The short of it is that you would add this in a script tag prior to loading the API:
var dojoConfig = {
	has: {
		"featurelayer-snapshot-enabled": 0 // disable snapshot
This is derived from this thread, at the end of the solution post.  For reference, these settings are found in the esri/core/has.js file.
