Proxy Dynamic Token Error - urgent
1620
02-09-2011 02:20 AM
AlexanderAnkrah
Hi Guys,
I have a secure service and using the proxy pages suggested here http://forums.esri.com/Thread.asp?c=158&f=2396&t=297001
All works OK for the unsecured services on the server I'm trying to access But falls apart when I try access the secured services. I'm getting {"error":{"code":400,"message":"","details":["Unauthorized access"]}}
Is there any configuration step I'm missing? This is really daft 'cos it worked well when we last used it for printing...
I've placed these
esri.config.defaults.io.proxyUrl = "proxy.ashx";
esri.config.defaults.io.alwaysUseProxy = true;
in my init ()
and in the proxy I have
<serverUrl url="http://MYSERVER/ArcGIS/rest/services/Secure/MYSERVICE/MapServer"
               matchAll="false"
               dynamicToken="true"
               host="gis.MyCOMPANY.org.YYY" //**had http here but no joy
               userName="someName"
               password="somePassword"></serverUrl>
Anything I'm missing?
Thanks
dON
PragneshPatel
Hi Guys,
I've placed these
in my init ()
               matchAll="false"
               dynamicToken="true"
               userName="someName"
Thanks
dON
hi did you managed to solve this problem?
nicogis
Pragnesh, have you tried to go in debug on proxy.ashx? so you see problem
DerivenC
Can't believe I missed this thread (and instead created a new one).  The issue I found is that cookies are not being sent in version 3.0, meaning your secure cookie isn't being sent -- this the "unauthorized access".
I submitted the error here:
http://forums.arcgis.com/threads/61348-BUG-In-3.0-No-Cookie-Present-in-Proxy-Requests
Workaround is to use version 2.8 for now.
RoyJackson1
When I had this problem, it was because I had windows authentication turned on in IIS.  The proxy page did not have permission to run.  I had to change the proxy page to include windows credentials.
onto line 59:
System.Net.WebRequest req = System.Net.WebRequest.Create(new Uri(uri));
  req.Method = context.Request.HttpMethod;
        req.Credentials = new NetworkCredential("USERNAME", "PASSWORD", "DOMAIN");
HTH
