PROJECTING WGS1984(102100) GEOMETRY TO WKT
1086
05-22-2023 12:23 PM
ACHANUMA
Hi Friends,
I am trying o project  certain points in wgs84 (wkid: 102100) to a custom projection (wkt shown below) in a WAB widget (running on jsapi 3.27 ) .  FYI, i cannot use a wkid as its a custom projection with modified parameters.
    PROJCS["NAD_1983_UTM_Zone_11N",GEOGCS["GCS_North_American_1983",DATUM["D_North_American_1983",SPHEROID["GRS_1980",6378137.0,298.257222101]],PRIMEM["Greenwich",0.0],UNIT["Degree",0.0174532925199433]],PROJECTION["Transverse_Mercator"],PARAMETER["False_Easting",1640416.666666667],PARAMETER["False_Northing",0.0],PARAMETER["Central_Meridian",-117.0],PARAMETER["Scale_Factor",0.9996],PARAMETER["Latitude_Of_Origin",0.0],UNIT["Foot_US",0.3048006096012192]]
My Sample Code:
// input SPRS
var inputSRS=new SpatialReference({
            wkid:102100
// Output SPRS
var outputSrs = new SpatialReference({"wkt": 'PPROJCS["NAD_1983_UTM_Zone_11N",' +
        'GEOGCS["GCS_North_American_1983",DATUM["D_North_American_1983",' +
        'SPHEROID["GRS_1980",6378137.0,298.257222101]],' +
        'PRIMEM["Greenwich",0.0],' +
        'UNIT["Degree",0.0174532925199433]],PROJECTION["Transverse_Mercator"],' +
        'PARAMETER["False_Easting",1640416.666666667],PARAMETER["False_Northing",0.0],' +
        'PARAMETER["Central_Meridian",-117.0],' +
        'PARAMETER["Scale_Factor",0.9996],'+
        'PARAMETER["Latitude_Of_Origin",0.0],'+
        'UNIT["Foot_US",0.3048006096012192"'
 // Projection logic
projection.load().then(lang.hitch(this,function()
            var projectedPoints = projection.project(inputPoints, this.outputSrs);
            projectedPoints.forEach(function(point) {
                console.log(point.x, point.y);
I getting the below error msg when the code tried to project the input points. Just wondering of jsapi 3.27 version has a known bug with SPRS that are defined using wkt instead of wkid.
init.js:115 Error: Illegal Argument Exception: Cannot create SpatialReference from text.
at d.F (geometryEngine.js:537:23)
at b.OY (geometryEngine.js:1152:308)
at b.uR (geometryEngine.js:1145:481)
at g.Ao (geometryEngine.js:1145:167)
at d._getTransformation (geometryEngine.js:1276:490)
at p (projection.js:4:417)
at l (projection.js:4:273)
at d.project (projection.js:5:422)
at Object.<anonymous> (Widget.js?wab_dv=2.14:584:46)
at init.js:64:337 'Error: Illegal Argument Exception: Cannot create SpatialReference from text. \n at d.F (https://js.arcgis.com/3.27/esri/geometry/geometryEngine.js:537:23)\n at b.OY (https://js.arcgis.com/3.27/esri/geometry/geometryEngine.js:1152:308)\n at b.uR (https://js.arcgis.com/3.27/esri/geometry/geometryEngine.js:1145:481)\n at g.Ao (https://js.arcgis.com/3.27/esri/geometry/geometryEngine.js:1145:167)\n at d._getTransformation (https://js.arcgis.com/3.27/esri/geometry/geometryEngine.js:1276:490)\n at p (https://js.arcgis.com/3.27/esri/geometry/projection.js:4:417)\n at l (https://js.arcgis.com/3.27/esri/geometry/projection.js:4:273)\n at d.project (https://js.arcgis.com/3.27/esri/geometry/projection.js:5:422)\n at Object.<anonymous>
Your help is appreciated.
A
UndralBatsukh
Seems like you have an issue in the WKT text. The WKT is supported when projecting. For instance, there is two pp here: PPROJCS I removed this and was not able to project it. So I have used this WKT: https://spatialreference.org/ref/epsg/nad83-utm-zone-11n/esriwkt/ and projection happens as expected.
This codepen shows a proof of concept in 4.26. https://codepen.io/U_B_U/pen/RwevmgB?editors=1000
