Hi all,
We have a situation where we want to override the default popup location and position the popup precisely on the feature. This works fine if the user hasn't panned 'around the world'. If the user has panned around the world, using the original feature location, the popup is positioned off the map.
For example, in this screenshot, the user clicked on the marker off the coast of Africa.
It seems the web mercator coordinates of the click differ between the markers, but the geometries themselves are the same.
Looking for possible solutions here.
Attaching sample code that demonstrates issue for good measure.
Thanks in advance.
Greg
<html>
<head>
<meta charset="utf-8">
<meta name="viewport" content="initial-scale=1, maximum-scale=1, user-scalable=no">
<title>ArcGIS Maps SDK for Javascript : Marker Playground</title>
<style>
html,
body,
#viewDiv {
padding: 0;
margin: 0;
height: 100%;
width: 100%;
</style>
<link rel="stylesheet" href="https://js.arcgis.com/4.25/esri/themes/light/main.css">
<script src="https://js.arcgis.com/4.25/"></script>
<script>
require([
"esri/config",
"esri/Map",
"esri/views/MapView",
"esri/Basemap",
"esri/Graphic",
"esri/geometry/Point",
"esri/PopupTemplate",
"esri/core/reactiveUtils"
], function(esriConfig, Map, MapView, Basemap, Graphic, Point, PopupTemplate, reactiveUtils) {
// api key
esriConfig.apiKey = "";
// init the map
const map = new Map({
basemap: "topo-vector"
const view = new MapView({
map: map,
center: [0,0],
zoom: 1,
container: "viewDiv",
constraints: {
//minZoom: 2
const template = {
title: "{name}"
const graphics = new Graphic({
geometry: {
type: "point",
x: 0,
y: 0,
spatialReference: {
wkid: 102100
attributes: {
popupTemplate: template,
symbol: {
type: "text", // autocasts as new TextSymbol()
color: "blue",
text: "\ue61d", // esri-icon-map-pin
font: {
// autocasts as new Font()
family: "CalciteWebCoreIcons" // Esri Icon Font
view.graphics.add(graphics);
// listen for marker click
reactiveUtils.watch(
() => view.popup.selectedFeature,
(feature) => {
if (feature) {
if (feature.isAggregate) return;
const { geometry } = feature;
const point = new Point(geometry);
view.popup.location = point;
// Set up a click event handler
view.on("click", function(event) {
console.log("Click event emitted: ", event);
console.log("Current view extent: ", view.extent);
</script>
</head>
<body>
<div id="viewDiv"></div>
</body>
</html>
