Programmatically open a popup template on a graphic
6626
12-07-2020 04:08 AM
by Anonymous User
Not applicable
In the API docs, https://developers.arcgis.com/javascript/latest/api-reference/esri-PopupTemplate.html#content, it is mentioned that the pop up template is open using clicks by default. Is there a way to programmatically open a popup template on a graphics layer?
Currently, the only available methods is to open up the pop up on a view.
view.popup.open()
But what I am looking for is, say that I have graphicsLayer initialised as a feature layer
graphicsLayer.graphics.getItemAt(x).popupTemplate.open()
Tags (1)
RobertScheitlin__GISP
You just use this line of code:
view.popup.open({
  features: graphics  // array of graphics or a single graphic in an array
view.popup.open({
DiegoMonge_Chinchilla
Hi
Is this possible with a featurelayer content.
For example I'm trying to do this:
var districts = new FeatureLayer({
      url: "https:.../server/rest/services/Distritos_SNIT/MapServer/0",
      outFields: ["nom_cant", "nom_prov", "nom_distr","cod_prov","cod_distr","cod_canton"],
      renderer: renderer,
      labelingInfo: [labelClass],
      popupTemplate: {
        content: "<b>Provincia: </b>{nom_prov} ({cod_prov})<br/> <b>Cantón:</b> {nom_cant} ({cod_canton})<br/> <b>Distrito:</b> {nom_distr} ({cod_distr})",
        title: "Ubicación del punto",
popup.open({
                title: "Esta es la ubicación de su punto",
                feature: [districts],
                content: "{nom_prov}"
And I got the following error:
(index):119 [esri.core.Accessor] Accessor#set Assigning an instance of 'esri.layers.FeatureLayer' which is not a subclass of 'esri.Graphic'
Any thought ?
Regards
@DiegoMonge_Chinchilla  Just like the error is telling you, You are passing a FeatureLayer to the popups feature property when it is expecting a Graphic or array of Graphics. So something like
const query = new Query();
query.where = "1=1";
query.outSpatialReference = { wkid: 102100 };
query.returnGeometry = true;
query.outFields = [ "nom_prov" ];
districts.queryFeatures(query).then(function(results){
  popup.open({
    feature: results.features[0],
 Would work.
Thanks a lot
I forgot to mention that I'm not a developer, I'm forest engineer so I don't know much about coding.
After a few tries it works with the following adjustments in case someone else needs it:
const query = districts.createQuery();
            query.geometry = view.center;
            query.spatialRelationship = "intersects";
            // query.distance = 2;
            // query.units = "meters";
            query.returnQueryGeometry = true;
            query.outFields = ["nom_prov"];
            districts.queryFeatures(query).then(function (results) {
                console.log(results)
                popup.open({
                    // feature: results.features[0],
                    content: results.features[0].attributes.nom_prov
Thanks a lot for your kind help @RobertScheitlin__GISP
