Problems with Javascript Editor Widget
3898
05-08-2015 06:33 PM
OmairChaudhry
I am using the editing widget in my web application. I have published a point feature service with update and delete option unchecked and I have enabled attachment on this service. The two issues I am having are:
1. The upload attachment button does NOT come up with the info window when I place marker on the map. It only comes after the info window is closed and click on the marker again.
2. If I place another maker the field values I have set for the first marker are not cleared by default.
Both of issues go away if I enable update on the feature service. But I don't want to enable update since that would mean users can edits other users field values.
Can someone please help I am stuck!
OZ
