problems disabling navigation during edits when using infoTemplate
5671
14
01-21-2016 08:36 AM
TracySchloss
Honored Contributor
I know there are many threads on editing and navigation, but I still can't figure it out.  I want to be able to enable/disable editing on my featureLayer.
I have a boolean set as app.editEnabled.
I have the button constructed as a toggleButton:
      createEditButton: function (){
          var tglButton = new ToggleButton({
           showLabel: true,
           label: 'Begin Editing',
            onChange: function(val) {
            if (val){
                this.set('label', 'Stop Editing');
                app.editEnabled = true;
            }else{
                this.set('label', 'Begin Editing');
                app.editEnabled = false;
        }, "tglEditButton");
It is properly changing my Boolean and my button label.
      var template = new PopupTemplate({        title: null      });
        template.setContent(setPopupContent);
My FeatureLayer is defined as
    featureLayer =  new FeatureLayer(pathName+"/arcgis/rest/services/MDA/sampleGeocodeEdit/FeatureServer/0",{
        outFields:['*'],
     infoTemplate:template
//symbology defined elsewhere
     featureLayer.renderer = renderer;
     featureLayer.setSelectionSymbol(highlightMarkerSymbol);
I have a listener on it:
     on(featureLayer, "click", function(evt){
       map.infoWindow.hide();
       formatString = "";
       objectId = evt.graphic.attributes[featureLayer.objectIdField];
       selectQuery.objectIds = [objectId];
       featureLayer.selectFeatures(selectQuery);
         if (app.editEnabled) {
           myEditor.activateToolbar(evt.graphic,map);
in myEditor
     activateToolbar: function (graphic,map) {
         map.disableMapNavigation();
          map.disablePan();
         app.editToolbar.activate(Edit.MOVE, graphic);
         on(app.editToolbar, 'graphic-move-stop', function(evt){
           featureLayer.applyEdits(null, [graphic], null);
           app.editToolbar.deactivate();
           map.enableMapNavigation();
There is where I'm getting stuck.  Instead of the graphic moving when I drag the mouse, it still just pans the screen instead.     As long as my feature doesn't have an infoTemplate, the graphic drags.  Once I include one in my featureLayer constructor, navigation is not disabled and instead of dragging the graphic, it just pans.  I've tried hiding the infoWindow, but it isn't getting removed.
TracySchloss
Honored Contributor
I understand the way you're describing it, but there's a good chance the user might have an infoWindow open before they start.  They may see some information that needs to be changed and then click Start Editing.  Even though the graphic seems like it might be selected, because you just clicked it to see the information, it isn't.
thejuskambi
Ok, now I understand what you mean.
Change the below function in myEditor.js file.
          createEditButton: function (map) {
                    showLabel: true,
                on(tglButton, 'change',lang.hitch(this, function (val) {
                    if (val) {
                        var selected = featureLayer.getSelectedFeatures();
                        if(selected && selected.length > 0){
                            var graphic = selected[0];
                            this.activateToolbar(graphic, map);
                    } else {
The idea is to get the selected feature and setup the edit Toolbar when the graphic is already selected. I have not tested the code. Also you need to require dojo/_base/lang.
Hope this helps.
TracySchloss
Honored Contributor
With the lang.hitch, the use of 'this' doesn't work.  It's giving the error 'this.set is not a function'.  I get what you're saying, though.
thejuskambi
That's because I have changed the scope of the function. Change it to
tglButton.set('label', 'Stop Editing');
and
tglButton.set('label', 'Begin Editing');
or get the instance of ToggeButton and set the label.
TracySchloss
Honored Contributor
OK, that fixed that, but the map navigation gets turned back off again after moving it one time.  I'll have to look at the activateToolbar function next.   It's enabling mapNavigation at the end of every graphic-move-stop.
