Hi all, I am using Chris Sergent's print used in his simple map somewhat successfully, however not all of my layers are getting sent to the legend - only the one layer that is visible when the map is loaded is turning up in the legend. I have several checkboxes where the user can turn on and off other layers, and if this is done, these layers are not being sent to the legend. They do end up in the printed map, with the exception of the layer that was visible by default on map load. For some reason turning on/off any other layers causes this one layer to be removed from the final print. Is there some sort of refresh of the print tool that can be done?
