problem with map.graphics.add(graphic);
6100
14
04-29-2014 11:20 AM
GyeyoungChoi
Hi all,
function getLocRes(results) {
 //map.graphics.clear();
 var symbol = new esri.symbol.SimpleFillSymbol(esri.symbol.SimpleFillSymbol.STYLE_SOLID, new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_SOLID, new dojo.Color([80, 0, 0]), 2), new dojo.Color([80, 0, 0, 0.5]));
 var combinedExtent = new esri.geometry.Extent();
 console.log("er",results.features.length);
 for (var i = 0;i < results.features.length; i++) {console.log("i=",i);
  var polyGraphic = new esri.Graphic(results.features, symbol);
  console.log("i=",polyGraphic);
  polyGraphic.setSymbol(symbol);
  //map.graphics.add(graphic);
 combinedExtent = esri.graphicsExtent(results.features);
 map.setExtent(combinedExtent, true);
this function is working sort of  but when I enable either
or
it stops where the code is
this shows
only 0 when map.graphics.add(graphic); is on
if not it doesn't add graphic but shows console.log("i=",i); result until the end
Am I missing something here that map.graphics.add(graphic); shouldn't work?
dojo.require("dijit.layout.BorderContainer");
dojo.require("dijit.layout.ContentPane");
dojo.require("esri.map");
dojo.require("esri.dijit.Popup");
dojo.require("esri.dijit.Legend");
dojo.require("esri.layers.agsdynamic");
dojo.require("esri.layers.ArcGISTiledMapServiceLayer");
dojo.require("dijit.dijit");
dojo.require("esri.tasks.find");//search
dojo.require("esri.arcgis.utils");
dojo.require("esri.dijit.Print");
dojo.require("dojox.grid.DataGrid");
dojo.require("dojo.data.ItemFileReadStore");
dojo.require("dijit.form.Button");
dojo.require("esri.tasks.query");
dojo.require("esri.dijit.Scalebar");
dojo.require("esri.graphic");
dojo.require("esri.symbol");
JonathanUihlein
You are trying to add an object that does not exist. You want to add 'polyGraphic' to the map.
map.graphics.add(polyGraphic);
Also, make sure you have access to your map object within that functional scope.
GyeyoungChoi
oops, but anyways that wasn't problem still does same thing
and I have full access to the map as well
any suggestions?
I've tried
  var polyGraphic = results.features;
both stop at either map.graphics.add(polyGraphic); or  map.graphics.clear();
Thanks Jon
JonathanUihlein
Could you recreate the issue using jsfiddle.net so I can take a closer look? Thanks!
GyeyoungChoi
I tried using jsfiddle but here is url
JonathanUihlein
Unfortunately, this doesn't help because your application is simply too big for me to spend time digging through.
I really need you to strip out all the unnecessary code and create a sample that highlights your specific issue using jsfiddle.net.
Sometimes, when doing this, the issue presents itself, so I suggest giving it a try!
Sorry and thank you!
GyeyoungChoi
thanks Jon
I'll try to put my code on jsfiddle soon
GyeyoungChoi
here is how it works and problems:
url looks like http://my.com/test.htm?bldgabbrv=msc,sup3,gsc,rudd,cen
query.where = Abbrev = 'MSC' OR Abbrev = 'SUP3' OR Abbrev = 'GSC' OR Abbrev = 'RUDD' OR Abbrev = 'CEN'
then queryTask.execute(query, getLocRes);
if you look at getLocRes
script stops where map.whatever without them script just goes (tested with bunch of console.log)
tried for and while but they were not a problem.
The Funny thing is when I add alert(); right before queryTask.execute the function works perfect.
Does anyone knows what I did wrong?
Thanks!
*update on jsfiddle when u click run it should select 4 polygons in maroon color
GyeyoungChoi
So the problem with this is
error: Cannot read property 'add' of null
[ATTACH=CONFIG]33536[/ATTACH]
I am not sure what this means... does anyone knows about this?
GyeyoungChoi
on firebug says
error: map.graphics is null
still doesn't make any sense
