Print widget painfully slow to load after update to 4.31
1277
11-13-2024 07:23 AM
MappyIan
After the update to 4.31, the standard Print Widget is really slow to load (23 seconds).  You can see it on the ESRI Sandbox: https://developers.arcgis.com/javascript/latest/sample-code/sandbox/?sample=widgets-print
Changing back to use 4.30, the Print Widget loads much quicker (8 seconds).
I presume/hope ESRI are aware?  But some sort of response to know that this is in hand would be really helpful.
ReneRubalcava
Esri Frequent Contributor
It's the print service, not the SDK. It's taking longer than usual to load and should be up and running in a bit.
ReneRubalcava
MappyIan
Thanks @ReneRubalcava, that's reassuring that the speed issue should be resolved soon.
