PortalItem (ArcGIS Dashboards) JSON to HTML
1883
05-05-2023 11:16 AM
MahmudHamid
Hello Everyone,
I have searched a lot within the documentation but could not get an answer or a guid.
I have a Vue.js app which is suppose to take a public ArcGIS Dashboard ID as an input and fetch its data and display the dashboard to the user. I know this can be done easily through embedding the URL of the dashboard in an iframe tag but is there a way to do this programmatically by only taking the ID of the dashboard?
For now I'm using the following code to fetch the data of the dashboard:
new PortalItem({
 }).load().then(function (item) {
  item.fetchData().then(function(itemData) {
     console.log(itemData);
That code gets the JSON representation of the dashboard, so is there any way to render the dashboard to the user using that JSON data?
Thanks so much!!
Tags (3)
jcarlson
All the display stuff is coming from the dashboard app itself. For our portal, that's
https://maps.co.kendall.il.us/portal/apps/opsdashboard/index.html#someitemid
So the assets needed to render the dashboard are at that path, and it reads the JSON based on the itemID.
- Josh Carlson
Kendall County GIS
MahmudHamid
So you're saying that there is no way to display the dashboard other than calling the dashboard URL? In other words using embedded iframe?
jcarlson
I don't know if there's no way, but an embedded frame would be a lot easier, otherwise you'll have to copy out the HTML, CSS, and JS resources that make the dashboard actually work.
- Josh Carlson
Kendall County GIS
