Lasso / Rectangular Select event from Sketch Widget?
999
05-05-2023 12:04 PM
AndrewMurdoch1
Good Day
I have the Sketch Widget active on my map, and if I use the Draw tools, the "create" event will send a signal, and I can query the features without issue:
        sketchWidget.on("create", async (event) => {
          if (event.state === "complete") {
            this._view.graphics.removeAll();
            const geometries= this.sketchLayer.graphics.map((graphic) => {
              return graphic.geometry
            const queryGeometry = await geometryEngineAsync.union(geometries.toArray());
            this.selectFeatures(queryGeometry);
When I use lasso or rectangle select tool, no signal is thrown, that I can find.  Oddly enough, if I use the "Select Feature" option, to select a single feature, the click handler on the view works fine.
What should I do, to get signals from the lasso and rectangle selection options?
