polygons with modal window and different information
1147
12-30-2019 11:55 AM
EdgarCampos
Hi
I am working with information from this url
Display point, line, and polygon graphics | ArcGIS for Developers
what I need is to have two or more polygons and that each one has a modal window with different information
RobertScheitlin__GISP
Edgar,
   The map popup window (added in the challenge portion) is a singleton object (meaning that there can only be one at a time). As long as you are not wanting to have the popup showing for more than one polygon at a time then you just need to add the polygons with different attributes.
EdgarCampos
Thanks!!!
