polygon vertices shift after using cutOperator
441
12-17-2025 08:02 AM
clementlaskar
Hello,
I'm trying to use the cutOperator to split a polygon with a polyline.
https://developers.arcgis.com/javascript/latest/api-reference/esri-geometry-operators-cutOperator.ht...
Cutting the polygon alongside the line seems to be successfull. However the other vertices are slightly shifted, causing topological issues.
Using the Editor widget, I don't see any problem, cutting the geometry is ok and no vertex shift.
What could be the problem ?
clementlaskar
I was cutting the feature graphic that I fetched using a mapView hitTest.
I changed to get the feature geometry directly from the service.
Using the cutOperator with the geometry from the service is fine and I don't get vertices shift.
