DOM element can not be queried by querySelector after added into to MapView.ui with v4.34
781
11-17-2025 10:07 AM
AllenHuang
In JS API v4.34, I'm trying to add DOM element to the map view MapView.ui.add().
The element is added to the map slot (used to be position)  correctly, however, when I tried to use querySelector to look for it by id or class name, querySelector wouldn't be able to find it in from the root document and returns null.
I also observed that style definition define in the css file on the same id or class name would not apply either.
Here is a sample code
js script
//When using v4.34
 let infoPanel = document.createElement('DIV');
 infoPanel.className = 'infoPanel border';
 infoPanel.innerHTML = 'Info Panel';
 infoPanel.style.borderWidth = '1px';
 infoPanel.style.borderColor = 'blue';
 infoPanel.style.borderStyle = 'solid';
 let arcgisMap = document.querySelector('arcgis-map');
 arcgisMap.view.ui.add(infoPanel, 'top-right');
 // a element would be added to the top-right corner of the map with text 'Info Panel' enclosed by a blue border with squared corners and transparent background
 console.log(document.querySelector('arcgis-map')) //console print out null
css file
.infoPanel, #panelHeader {
    background-color: white;
    border-radius: 0.5rem 0.5rem 0rem 0rem;
} /* this is suppose to modify the element with corned top corners and a white background. But these styles was not reflected by the generated element by the JS script */
Is this a bug? This code worked properly in v4.33
ReneRubalcava
Esri Frequent Contributor
FC_Basson
Instead of defining a class for the div element, you can try setting the "part" attribute, which will be available as a selector for your CSS.
infoPanel.setAttribute("part", "infoPanel border")
Then in the CSS:
*::part(infoPanel) {
