Points with InfoWindow attached to it
5201
6
05-06-2015 05:37 AM
ThomasSpillard
I created a map with some points on it with the ESRI JavaScript API.
I would now like to attach a InfoWindow (or pop-up, ...) to the point so that when you click on a point, the info window shows with information in it .
I am new to this and haven't found what i wanted so i'm asking here, please tell me if this is inappropriate.
Thanks in advance,
Thomas
TimWitt2
Are those points graphics? If so check out my example here: Button Popup 1 - JSFiddle
Tim
JaiSiva1
Hi Thomas,
Assuming that you have used FeatureLayer in your map , i am suggesting the following code :
var map;
      require(["esri/map",
                  "esri/layers/FeatureLayer",
                  "esri/InfoTemplate",
                  "dojo/domReady!"], function(Map,FeatureLayer,InfoTemplate) {
          map = new Map("map", {
          basemap: "topo",  //For full list of pre-defined basemaps, navigate to http://arcg.is/1JVo6Wd
          center: [0, 0] // longitude, latitude
  var infoTemplate = new InfoTemplate("${NAME}", "${*}");  // Info template definition
  var featureLayer = new FeatureLayer("http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Demographics/ESRI_Census_USA/MapServer/3", {
          infoTemplate: infoTemplate // assigning the Info template to the feature layer
  map.addLayer(featureLayer);
ThomasSpillard
In my case i have implemented the map in an other app where I query a table with GlideRecord to create those points, so i it would mean i have to do a Dynamic Layer ? Thanks a lot for your help
TimWitt2
Tim
RickeyFight
Thomas,
Here is a link that will help you with info windows/popups  Samples | popups_and_info_windows,
and InfoWindow | API Reference
Tim Witt​'s example is very nice too!
ThomasSpillard
Hi Rickey,
Indeed I have went through the API References but didn't figure out i had to put the info window and point together in a graphic, Thanks a lot too
Thomas
ThomasSpillard
I think this is the best solution for me,
Thanks a lot !
Thomas
