PictureMarkerSymbol on click open Popup
4585
07-23-2015 07:01 AM
PauliusButkus
I am creating map, where I have marker(pins), which are PictureMarkerSymbol objects. When you click on them, popup appears, in which more data about this marker also appears. What you can offer for me to use, to create this functionality?
What I have: PictureMarkerSymbol objects on map.
What I need: When you click them, popup with it's data appears.
ChrisSmith7
Honored Contributor
Paulius,
If you are using the JavaScript API, have a look at the following for some ideas:
Feature collection | ArcGIS API for JavaScript
Popup | ArcGIS API for JavaScript
PauliusButkus
I saw these ideas, but almost all examples have his data from services nowhere I found, how to do this with PictureMarkerSymbols.
