PictureFillSymbol not coming after print
2591
7
01-12-2022 12:02 PM
by Anonymous User
Not applicable
I am trying to print polygon filled with pictureFillSymbol. The pictureFillSymbol is available on the map, but when we print it as PDF it's not available. Any idea why it's happening? I am using ArcGIS JavasScript APi  3.39
Below is the way I am using for pictureFillSymbol symbol:
https://developers.arcgis.com/javascript/3/samples/playground/main.html#/config=symbols/PictureFillS...
and PictureFillSymboll class: https://developers.arcgis.com/javascript/3/jsapi/picturefillsymbol-amd.html
Thank you for help
Noah-Sager
Figured it out. The issue is that 3x does not automatically send the contentType for the symbology from json data to the print service. 4x does this automatically, which is why it prints there. The workaround for 3x is to add the appropriate contentType to the PictureFillSymbol constructor, like this:
"contentType": "image/bmp"
var symbol = new PictureFillSymbol({
          "url": "data:image/bmp;base64,Qk0+CAAAAAAAAD4AAAAoAAAAgAAAAIAAAAABAAEAAAAAAAAIAABtCwAAbQsAAAIAAAACAAAA////AAAAAAD/////////////////////gACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAP////////////////////8AgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACA/////////////////////4AAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgAD/////////////////////AIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgP////////////////////+AAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAA/////////////////////wCAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAID/////////////////////gACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAP////////////////////8AgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACA/////////////////////4AAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgAD/////////////////////AIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgP////////////////////+AAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAA/////////////////////wCAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAID/////////////////////gACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAP////////////////////8AgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACA/////////////////////4AAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgAD/////////////////////AIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgA==",
          "height":20,
          "width":20,
          "type":"esriPFS",
Noah-Sager
Hi @Anonymous User, what url are you using for the fill? Is it accessible over https to the print server? If you have a simplified repro case, I can do some testing and investigating.
by Anonymous User
Not applicable
I am using picture url converted tobase64. Example url: "data:image/bmp;base64,{someCharacters}"
by Anonymous User
Not applicable
Hi @Noah-Sager I attached a simplefied case of my problem. I modified esri example from here: https://developers.arcgis.com/javascript/3/sandbox/sandbox.html?sample=widget_print_esri_request The circe with pictureFillSymbol apperas after click on map. Result is still the same. Picture fill not comming after print. I appreciate if you have a look and investigate this. You can copy and paste my code easly into esri sandbox.
by Anonymous User
Not applicable
Noah-Sager
Thanks @Anonymous User, I am investigating.
In the meantime, I see that this works properly with 4x, the current version is 4.22. Are you able to update to 4x? Almost all development efforts are now on the 4x version of the API, so we recommend that our users upgrade as soon as they are able.
test-app: https://codepen.io/noash/pen/jOGRaOe?editors=1000
Noah-Sager
          "height":20,
          "width":20,
          "type":"esriPFS",
by Anonymous User
Not applicable
I confirm that it works for me. You solved the problem. Thank you @Noah-Sager for your help and commitment
