Perform IdentifyTask within Edit operation and wait for Deferred to return
864
06-25-2014 06:27 AM
ShaneLim
I have a simple point editing javascript site.  I am trying to get the topmost layer feature and unique ID from an identify to link the new feature to the feature it intersects when place.  So if I place a new workorder on a hydrant I want the hydrant layer and the hydrants ID to populate in the workorder attributes.  The problem is identifyTask is differed and the add function on "before-apply-edits" function finishes before the deffered returns the values.    Is there a way to wait for the deferred or to move the differed into an update function to update the attributes with the values?
Below is my code.  I appologize in advance its pretty raw right now and I had to cut some to get under the character limit.
    <script src="http://js.arcgis.com/3.9/"></script>
    <script>
        var map;
        require([
          "esri/map",
          "esri/toolbars/edit",
          "esri/tasks/PrintTask",
          "esri/dijit/Geocoder",
          "esri/layers/ArcGISDynamicMapServiceLayer",
          "esri/layers/FeatureLayer",
          "esri/tasks/IdentifyTask",
          "esri/tasks/IdentifyParameters",
          "esri/dijit/editing/Editor",
          "esri/dijit/editing/TemplatePicker",
          "esri/config",
          "dojo/_base/array", "dojo/parser", "dojo/keys", "dojo/_base/Color", "dojo/dom-construct", "dojo/dom-class",
  "dijit/form/Button",
          "dijit/layout/BorderContainer", "dijit/layout/ContentPane",
          "dojo/domReady!"
        ], function (
          Map, Edit, PrintTask, Geocoder,
          ArcGISDynamicMapServiceLayer, FeatureLayer,
          IdentifyTask, IdentifyParameters,
          Editor, TemplatePicker,
          esriConfig,
          arrayUtils, parser, keys, Color, domConstruct, domClass, Button
            parser.parse();
            var identifyTask, identifyParams;
            // refer to "Using the Proxy Page" for more information:  https://developers.arcgis.com/en/javascript/jshelp/ags_proxy.html
            esriConfig.defaults.io.proxyUrl = "/proxy";
            //This service is for development and testing purposes only. We recommend that you create your own geometry service for use within your applications.
            esriConfig.defaults.geometryService = new esri.tasks.GeometryService("http://servername/arcgis/rest/services/Utilities/Geometry/GeometryServer");
            map = new Map("map", {
                basemap: "topo",
                center: [-116.140, 43.589],
                zoom: 16
            geocoder = new Geocoder({
                map: map
            }, "search");
            geocoder.startup();
            map.on("layers-add-result", initEditor);
            //add WorkOrders and Feature
            var facilityURL = "http://servername/arcgis/rest/services/UWID_MobileMap/MapServer"
            var facilityLayer = new ArcGISDynamicMapServiceLayer(facilityURL);
            map.addLayer(facilityLayer);
            var operationsPointLayer = new FeatureLayer("http://servername/arcgis/rest/services/UWID_WorkOrderEdit/FeatureServer/0", {
                mode: FeatureLayer.MODE_ONDEMAND,
                outFields: ["*"]
            map.addLayers([
            var printUrl = "http://servername/arcgis/rest/services/UWID_WorkOrderPrint/GPServer/WorkOrderPrint";
            printTask = new esri.tasks.PrintTask(printUrl, { async: true });
            pparams = new esri.tasks.PrintParameters();
            pparams.map = map;
            function initEditor(evt) {
                var templateLayers = arrayUtils.map(evt.layers, function (result) {
                    return result.layer;
                var templatePicker = new TemplatePicker({
                    featureLayers: templateLayers,
                    grouping: true,
                    rows: "auto",
                    columns: 3
                }, "templateDiv");
                templatePicker.startup();
                var layers = arrayUtils.map(evt.layers, function (result) {
                    return { featureLayer: result.layer };
                var settings = {
                    map: map,
                    templatePicker: templatePicker,
                    layerInfos: layers,
                operationsPointLayer.on("before-apply-edits", function (evt) {
                    var targetID = evt.target
                    var toAdd = evt.adds;
                    dojo.forEach(toAdd, function (add) {
                        //setupID to get assett data
                        var layerIDName = null;
                        var layerLegacyID = null;
                        //layerLegacyID, layerIDName = doIdentify(add);
                        //add.attributes.FCLASS = layerIDName;
                        //add.attributes.FACILITYKEY = layerLegacyID;
                        add.attributes.WORKID = new Date().valueOf();
                        //add.attributes.CREATEDBY
                        var test = new Date().toLocaleDateString();
                        var datenow = new Date();
                        var strDate = (datenow.getMonth() + 1) + "/";
                        strDate += datenow.getDate() + "/";
                        strDate += datenow.getFullYear();
                        add.attributes.CREATEDDATE = strDate;
                        add.attributes.LASTUPDATE = strDate;
                        //add.attributes.LASTEDITOR
                        identifyTask = new IdentifyTask(facilityURL);
                        identifyParams = new IdentifyParameters();
                        identifyParams.tolerance = 5;
                        identifyParams.returnGeometry = true;
                        //identifyParams.layerIds = [0, 2];
                        identifyParams.layerOption = IdentifyParameters.LAYER_OPTION_TOP;
                        identifyParams.width = map.width;
                        identifyParams.height = map.height;
                        identifyParams.geometry = add.geometry;
                        identifyParams.mapExtent = map.extent;
                        identifyTask.execute(identifyParams, function (idResults) {
                            idresult = idResults[0];
                            layerIDName = idresult.layerName;
                            layerLegacyID = idresult.feature.attributes.LEGACYID;
                var params = { settings: settings };
                var myEditor = new Editor(params, 'editorDiv');
                var printButton = new Button({
                    label: "Print", onClick: function () {
                        var workIDtoPrint = myEditor.attributeInspector.layerInfos[0].fieldInfos[0].dijit.value
                        print(workIDtoPrint)
                }, domConstruct.create("div", null, myEditor.attributeInspector.editButtons, "first"));
                domClass.add(printButton.domNode, "atiMyButton");
                myEditor.startup();
        function print(workIDT) {
            var ptemplate = new esri.tasks.PrintTemplate();
            // use the extent of the webmap in the output PDF
            console.log("work ID " + workIDT)
            ptemplate.preserveScale = true;
            pparams.template = ptemplate;
            pparams.extraParameters = { WorkIDToPrint: workIDT };
            printTask.execute(pparams, printComplete);
        function printComplete(result) {
            console.log("url " + result.url)
            window.open(result.url);
    </script>
