Pan controls ArcGIS4
5208
13
03-25-2024 05:04 AM
azy141
Hi I am looking to add pan controls in the form of arrows to an ArcGIS4 JS map but have been struggling to find the specific api to allow me to do this.
I was wondering if anyone had any input on how I could go about doing this?
Thank you
Egge-Jan_Pollé
Hi @azy141,
Can you please explain why you would want to add pan controls to your ArcGIS4 JS map? The reason I ask this, is because I think it is not necessary at all to add such controls to the user interface.
It is quite easy to pan the map - grabbing it with a left mouse click, using the arrow keys on your keyboard or just with your fingers on a mobile device.
So, the map is 'panable' by default. There is no need to add controls to activate a pan modus.
What is your opinion about this?
Cheers,
Egge-Jan
azy141
I was given this assignment as we are looking at building controls that are easier to use for accessibility reasons.
fdeters
In case anyone else comes across this in the future and is curious, here is a link to WCAG 2.2 SC 2.5.7 Dragging Movements, which requires that anything that "uses a dragging movement for operation can be achieved by a single pointer without dragging".
For WCAG 2.2 AA compliance purposes, it's not enough to provide keyboard controls for panning; you must also provide a pointer control that does not require dragging.
Egge-Jan_Pollé
I think you will have to add your own buttons to the map, or actually to the view.ui, with a function to move the center of the map an X number of units to the N/E/S/W when the respective button is clicked.
I have never added pan buttons to the ui myself, but for some inspiration you may have a look at this example, where I do add a custom 'previous extent' and 'next extent' button to the user interface:
ArcGIS Maps SDK for JavaScript example: Previous a... - Esri Community
HTH,
Egge-Jan
Paco
Hi.   I would assume you could just add some new html elements and change the MapView (view) by an x,y distance on each click.
Here I added custom zoom in/out buttons in a similar way-
document.getElementById("zoominbtn").addEventListener('click', function(){
  console.log("zoom in")
  var n= view.zoom + 1;
  view.zoom = n
document.getElementById("zoomoutbtn").addEventListener('click', function(){
  console.log("zoom out")
  var n= view.zoom - 1;
  view.zoom = n
ReneRubalcava
Esri Frequent Contributor
There is a DirectionalPad widget, it's not in the corners though, not sure if that would meet your needs
https://developers.arcgis.com/javascript/latest/api-reference/esri-widgets-DirectionalPad.html
azy141
This is perfect thank you
Egge-Jan_Pollé
Hi @ReneRubalcava,
Cool. Didn't know about this little widget. I did quickly create a small sample to test it (see code below) and it works fine. I do like this little compass indicating the orientation of the map (when not 0), allowing you to reset the map orientation (to 0).
Of course I cannot speak for the original poster, but I think this offers most of the functionality requested.
Here is my little sample:
<!DOCTYPE html>
<html>
<head>
  <meta charset="utf-8">
  <meta name="viewport" content="initial-scale=1, maximum-scale=1, user-scalable=no">
  <title>ArcGIS JavaScript with UK data - DirectionalPad</title>
  <link rel="stylesheet" href="https://js.arcgis.com/4.29/esri/css/main.css">
  <script src="https://js.arcgis.com/4.29/"></script>
  <style>
    html, body, #viewDiv {
      padding: 0;
      margin: 0;
      height: 100%;
      width: 100%;
  </style>
  <script>
      require([
        "esri/Map",
        "esri/geometry/Point",
        "esri/views/MapView",
        "esri/widgets/DirectionalPad"
      ], function(Map, Point, MapView, DirectionalPad) {
      var map = new Map({
        basemap: {
          portalItem: {
            // GB Cartographic Local Names, hosted by EsriUKContent, see: https://www.arcgis.com/home/item.html?id=5b9d5ac7e17f402a9111f1ca2c22bf56
      var view = new MapView({
        spatialReference: 27700,
        container: "viewDiv",
        map: map,
        center: new Point({x: 500000, y: 500000, spatialReference: 27700}),
        zoom: 5
      const directionalPad = new DirectionalPad({
        view: view
      view.ui.add(directionalPad, "bottom-right");
  </script>
</head>
<body>
  <div id="viewDiv"></div>
</body>
</html>
Cheers,
Egge-Jan
azy141
Do you know how I could go about overriding the icons used in this d pad?
