orderBy for SceneView
1274
11-01-2022 01:29 PM
wolfvincent
Dear all,
Could anyone tell me when this will be available for SceneViews? https://developers.arcgis.com/javascript/latest/api-reference/esri-layers-GeoJSONLayer.html#orderBy
Cheers,
Vincent
VeronikaLanders
Hi Vincent,
this is in our backlog but not yet planned for a release.
Could you please explain the use case you are trying to solve using this property? This helps us to prioritize our backlog.
Veronika
wolfvincent
Hi Veronika, thansk for your answer. It would be for the purpose of
visualizing areas on top of other areas: design for dikes and designs for
overlapping measurements. Would be really helpful to have it, now we need
to use separate layers... 🙂
Thanks!
Vincent
VeronikaLanders
Thanks Vincent - quick follow up question. Are you using a draped visualization (elevationInfo on-the-ground)?
wolfvincent
Hi Veronika, I'm using default, that's the on-the-ground modus right?
Thanks 🙂
VeronikaLanders
Sorry I missed to reply for so long - yes, this is the default if your polygons do not have z coordinates.
We have logged your case for prioritizing this feature.
