operations dashboard: target shortcut error
9146
10
07-17-2015 08:09 AM
TaN
Hello!
I am trying to set up the operations dashboard shortcut (Set up a development environment | Guide | ArcGIS API for JavaScript ), but when I try to change the 'Target' (using /extdbg: path name to my widgets folder), I keep coming up with this error:
The name 'C:\Users\ta.nguyen\AppData\Local\Apps\2.0\PLDDNPK0.71C\L3JNERPN.MW\p...\widgets"'
specified in the Target box is not valid. Make sure the path and file name are correct
Do you have any tips for changing the Target of the Operations Dashboard shortcut?
Jianxia
Hi TA,
To create a widget for Web AppBuilder, Go to Web AppBuilder for ArcGIS (Developer Edition), download the developer edition, and refer to the topic of Create a custom in-panel widget
This post may help you as well
Web AppBuilder Developer Edition - Customization Resource List
Hope this helps,
Jianxia
