'NS_ERROR_FAILURE  location: "JS frame' using v3.2 of the API
2045
10-11-2012 02:06 PM
StephenLead
Honored Contributor
I'm seeing a few error messages if I run this simple sample from a Mac webserver directory. I'm getting the error message below, and the map fails to load:
Error: [Exception... "Failure"  nsresult: "0x80004005 (NS_ERROR_FAILURE)"  location: "JS frame :: http://serverapi.arcgisonline.com/jsapi/arcgis/?v=3.2 :: <TOP_LEVEL> :: line 15"  data: no]
Line 15
[ATTACH=CONFIG]18374[/ATTACH]
If I revert the code to use v2.8 the error messages disappear and the map loads. This code wasn't causing a problem for me previously.
The live sample doesn't cause the error message, implying that there's a problem with my web server - what should I be looking at in order to debug this? I'm not aware of having changed anything recently.
Steve
derekswingley1
Can you elaborate on "Mac webserver directory"? Are you using the apache instance that comes with OSX (that's what I use)? Some other web server? Anvil, perhaps (I personally haven't tried this one yet)?
What's the URL your using to access the sample via your browser?
StephenLead
Honored Contributor
Hi Derek,
Yep, I'm using the in-built Mountain Lion web server - after looking up how to configure it months ago I haven't touched it, and up until now it has "just worked".
The URL I'm using is file:///Library/WebServer/Documents/demos/test.html for the simple sample referenced above. This works when using v2.8 but fails when using 3.1 or 3.2
I just tried restarting the web server using sudo apachectl restart but this had no effect.
Steve
derekswingley1
Using "file:///Library/WebServer/Documents/demos/test.html" isn't actually using your web server. Your URL needs to start with "http://localhost/". If I had to guess, try http://localhost/demos/test.html. Obviously you can use your machine's name or your IP address in place of localhost.
StephenLead
Honored Contributor
Sorry, you're obviously right. I don't know why I made that simple mistake.
Thanks!
