Is ArcGIS Javascript API 3.2 compatible with ArcGIS server 10.0?
1188
10-11-2012 02:50 AM
rajneeshsingh
Hi All,
I just want to know what functionalities can I miss out if I use  ArcGIS Javascript API 3.2 with ArcGIS server 10.0.
I know there are some limitations like Printing Web Maps. What else can be the limitations ? What bugs can creep in ?
Thanks in advance for any help.
KevinGooss
in my experience you can keep upgrading your client side api without upgrading your ags.
But you need to be careful not to try to use functionality that is not supported by your ags.
the docs do a good job of pointing out these areas.
SunilPalkar
Yes its supported . I have tested on my machine. Only you have to change/modify  script and CSS tag...According to my information.
