No PopUp Info in Chrome
13426
25
03-29-2021 06:26 PM
FranciscoCastillo1
Hi, Everyone!
I wonder what's happening with my PopUp Windows because suddenly started to fail when I use Chrome browser and it works fine in Brave and IE. Is there something with the new Chrome update? I developed an app with ArcGIS API 3.23.
Thank you in advance.
Greetings!
ShadCampbell
Yes, this is a problem for ANY applications built with or using the Esri JavaScript API 3.30 or older.  This includes any downloaded Esri Templates, Web AppBuilder Developer Edition application, GeoCortex, older versions of Portal?, etc.
We have updated all of our older custom built applications to version 3.35 and it has fixed the problem.  We don't want to modify the code for applications that we downloaded or purchased so the issues persist.  We are hoping that Esri will fix this for older versions of the API so we can continue to use these applications built on them. @ShelleySchott - any update on this?
To reproduce try this codepen: https://codepen.io/shadc/pen/YzNQMaO?editors=1000
Change the zoom in chrome to 90% with the JSAPI version (line 20) to 3.30 and it does not work. Change it to 3.31 (or greater) and it does.
ShelleySchott
@ShadCampbell there Bug logged in the system which will address this issue for Portal users.
BUG-00013868: User is unable to identify or click on Map Viewer with Google Chrome version 89.0.4389.90 or higher for Portal for ArcGIS 10.7.1 or Portal for ArcGIS 10.8 on some machines.
The recommended workaround is to use Edge or Firefox while we wait for the fix.
Shelley Schott
Senior Consultant, Esri Australia
BjornSvensson
Esri Alum
This is a bug/experiment with Chrome 89 - https://bugs.chromium.org/p/chromium/issues/detail?id=1192449#c28
  • The change is only rolled out to some Chrome installations, which is why it works on some machines, but fail on others.
  • This impacts version 3.10-3.30 of the ArcGIS API for JavaScript.
See also the related Esri Support issue at https://support.esri.com/en/bugs/nimbus/QlVHLTAwMDEzODY4NA==
We are currently working on having Google roll back this breaking change in the Chrome browser, as well as investigating possible alternatives for the API.
ShadCampbell
@BjornSvensson Thanks for this explanation!  Glad they are rolling it back!  FYI, as of 90.0.4430.72 it's still present.
BjornSvensson
Esri Alum
@ShadCampbell  - this is a Chrome Experimental feature which is something they can turn on/off independently of the Chrome version you have.  It's not specifically tied to Chrome 89 or 90.
There's more info in the Chromium bug - https://bugs.chromium.org/p/chromium/issues/detail?id=1192449#c38
BjornSvensson
Esri Alum
FYI - looks like Google will roll back this change -- https://github.com/w3c/pointerevents/issues/100#issuecomment-818870316
