No Coordinates
5082
10
07-14-2017 01:09 AM
AhmadLibda
I learned that The spatial reference for a map is defined either by the extent passed to the map constructor or by the first layer added to the map.
coordinate system - Set custom spatial reference to base map in arcgis javascript api - Geographic I...
I am new to GIS. So this is my code:
   var govs= new TileLayer({
        url: "http://localhost:6080/arcgis/rest/services/services/MapServer",
        visible: false
    var map = new Map({ });
 var view = new MapView({
        container: "viewDiv",  // Reference to the scene div created in step 5
        map: map,  // Reference to the map object created before the scene
        zoom: 1,  // Sets zoom level based on level of detail (LOD)
        center: [86999,99999]  // Sets center point of view using longitude,latitude
    map.layers.add(govs);
I get a "Null" for both mapPoint.latitude and longitude when i print them in a popup using the code:
view.on("click", function (event) {
        event.stopPropagation(); // overwrite default click-for-popup behavior
        // Get the coordinates of the click on the view
        var lat = Math.round(event.mapPoint.latitude *1000 )/1000 ;
        var lon = Math.round(event.mapPoint.longitude * 1000) / 1000;
        view.popup.open({
            // Set the popup's title to the coordinates of the location
            title: "Reverse geocode: [" + lon + ", " + lat + "]",
            location: event.mapPoint // Set the location of the popup to the clicked location
        view.popup.content =  "Hello,, ";
Also, altering "center" in view constructor doesn't seem to affect the starting center point of the map. However, "zoom" works.
I also tried to define "spatial reference" within the view (but no use):
        center: [86999,99999] , // Sets center point of view using longitude,latitude
extent: { // autocasts as new Extent()
            xmin: 75639.85130000021,
            ymin: 70262.05010000058,
            xmax: 108900.84379999992,
            ymax: 111618.54690000042,
            spatialReference: 28191
RobertScheitlin__GISP
Ahmad,
This works fine for me:
<!DOCTYPE html>
<html>
<head>
  <meta charset="utf-8">
  <meta name="viewport" content="initial-scale=1,maximum-scale=1,user-scalable=no">
  <title>Get started with MapView - Create a 2D map - 4.4</title>
  <style>
    html,
    body,
    #viewDiv {
      padding: 0;
      margin: 0;
      height: 100%;
      width: 100%;
  </style>
  <link rel="stylesheet" href="http://js.arcgis.com/4.4/esri/css/main.css">
  <script src="http://js.arcgis.com/4.4/"></script>
  <script>
    require([
      "esri/Map",
      "esri/views/MapView",
      "esri/layers/TileLayer",
      "esri/geometry/Point",
      "dojo/domReady!"
    ], function(Map, MapView, TileLayer, Point) {
      var layer = new TileLayer({
      var map = new Map({});
      var pt = new Point({
        x: 86999,
        y: 99999,
        map: map,
        zoom: 1,
        center: pt
      map.layers.add(layer);
        var lat = Math.round(event.mapPoint.y *1000 )/1000 ;
        var lon = Math.round(event.mapPoint.x * 1000) / 1000;
        view.popup.open({
        view.popup.content = view.spatialReference.wkid.toString();
  </script>
</head>
<body>
  <div id="viewDiv"></div>
</body>
</html>
Ahmad,
Center: If set in the constructor, this property will be ignored if the viewpoint or extent properties are also set in the constructor.
Because you are setting the extent the center is ignored.
The mapPoint latitude and longitude will be null for a local coordinate system like you are using if you want the mapPoint coordinates you need to use x and y.
AhmadLibda
I omitted the extent part, still changing the center is not doing anything
Have you tried using an actual lat lon cordinates and not your local XY value?
AhmadLibda
I do not know what you mean by "actual lat lon coordinates" but I tried a wide range of values, and I am always at the same starting point which is the center of my layers.
I mean
center: [34.336, 31.49]
These are the WGS 84 lat lon values for
AhmadLibda
no use
Ahmad,
<!DOCTYPE html>
<html>
<head>
  <style>
    html,
    body,
    #viewDiv {
      padding: 0;
      margin: 0;
      height: 100%;
      width: 100%;
  </style>
  <script>
    require([
      "esri/Map",
      "dojo/domReady!"
        x: 86999,
        y: 99999,
        map: map,
        zoom: 1,
        center: pt
        view.popup.open({
  </script>
</head>
<body>
</body>
</html>
AhmadLibda
Robert,
This works fine for me too
Thanks alot.
Ahmad,  great don't forget to mark this question as answered then.
