I hope this is posted in the right subforum.I'm using Arcgis and for some reason the little 'x' close button is not showing up on my info window. There aren't any errors listed on the page when I go into debug mode in the browser. I'm using version 2.7 but I have tried different versions to no avail.The code I use for displaying an InfoWindow:var template = new window.esri.InfoTemplate(); template.setTitle(self.getPopUpTitleContent); // self = this (yes, it's defined) template.setContent(self.getPopUpTextContent); self.featureLayer = new window.esri.layers.FeatureLayer(featureCollection, { mode: window.esri.layers.FeatureLayer.SELECTION_NEW, id: 'anAwesomeLayer', infoTemplate: template }); self.map.addLayers([self.featureLayer]); self.map.infoWindow.resize(275,275);
There should be a little 'x' on the right of the title bar:[ATTACH=CONFIG]19528[/ATTACH]Any help is greatly appreciated! Thanks in advance.
