No background image in the filteringSelect
1145
05-19-2017 01:41 PM
SaraEL_MALKI
as the image above shows, my filtering Select does not contain the arrow down nor the exclamation mark, the path in the file claro.css says it's in form/images/commonFormArrows.png and I don't know where that file is stored or or where should it be? to solve this issue I have downloaded by myself an image and changed the url but still does not work :
I am facing that problem with a lot of background images in my app like:
any thoughts ?
SaraEL_MALKI
Hi guys,
I have found a better theme in the API and it's called 'Calcite' when I've turn to it changing the Claro theme it turned out how AMAZING it is and this how the filtering Select looks :
SaraEL_MALKI
Hi guys,
