New to scripting - Need help with a basic script with functions
3900
15
02-26-2014 05:43 AM
SuzanneRoussie
I am in the process of putting together a basic map by learning off the tutorials and examples found on the JavaScript examples site and I am trying to use a home button, legend, and scale on the same map.  I had the home button and scale working but when I added the script for the legend it stopped working.  I was wondering if there was a limit on how many functions could be called the way I have it set up or if I am missing something else. I am sure there is a different way to do this but since I have never written anything in JavaScript before I thought this was the best way to learn. I have enclosed the text file of my code.
thanks,
Sue
MichaelVolz
Esteemed Contributor
Jake:
Here is the section you are talking about in my file:
//add the legend
      map.on("layers-add-result", function (evt) {
        var layerInfo = arrayUtils.map(evt.layers, function (layer, index) {
          return {layer:layer.layer, title:layer.layer.name};
        if (layerInfo.length > 0) {
          var legendDijit = new Legend({
            map: map,
            layerInfos: layerInfo
          }, "legendDiv");
          legendDijit.startup();
I do not see anywhere in this code where layers are being excluded, yet sampleserver3.arcgisonline.com mapservice layers are not being added to the legend.  I do not understand.
JakeSkinner
Esri Esteemed Contributor
I thought you were referring to ESRI's basemaps.
If the layers are not drawn, for example, due to a scale dependency they will not show in the legend.  Try adjusting the zoom level of your application.  Ex:
map = new Map("map", {
        basemap:"streets",
        center: [-96.509, 38.367],
        zoom: 14
MichaelVolz
Thanks Jake.  I did not realize that you had to zoom that far in for ESRI's river and waterbodies layers to show up.
KenBuja
MVP Esteemed Contributor
You do have the option of showing the legend for layers that are invisible due to scale dependency. Set the respectCurrentMapScale to false.
            map: map,
            layerInfos: layerInfo,
            respectCurrentMapScale: false
          }, "legendDiv");
MichaelVolz
I would like to add a dynamic mapservice to the javascript webmap.
I tried the following syntax but the mapservice does not show up.
var bound = new ArcGISDynamicMapServiceLayer("http://arcgis/ArcGIS/rest/services/MapServices/Bound_D/MapServer", {
        useMapImage: true
Can anyone tell me what I am doing wrong?
KenBuja
        useMapImage: true
You should start a new thread about this.
