new Map() versus arcgisUtils.createMap()
3543
04-03-2014 05:37 AM
DavidKimball1
This is a pretty basic question, but I haven't been able to find an answer after much searching.
I want to create a map in my custom Javascript API application from an ArcGIS.com web map. I have tried the following methods:
arcgisUtils.createMap(webmapid, "mapDiv").then(function (response) {map = response.map;});
and
map = new Map("mapDiv", {  basemap: "topo",  autoResize: false, // see http://forums.arcgis.com/threads/90825-Mobile-Sample-Fail  center: [-71.7, 42.35],  zoom: 8,  minZoom: 7,  logo: false,  slider: true,  sliderStyle: "small" });
The first one creates a map using my ArcGIS.com web map. The second one creates an empty map (basemap only) with a bunch of attributes I need (autoResize:false to deal with a map resize bug, etc). I want to do both - use my webmap and assign all those attributes to the map. How can I do this? Why are there two ways to create a map?
David
ReneRubalcava
Esri Frequent Contributor
arcgis.Utils.createmap takes a third options parameter.
https://developers.arcgis.com/javascript/jsapi/esri.arcgis.utils-amd.html#createmap
It looks a little odd at first, but you can do the following:
var mapOptions = {  basemap: "topo",  autoResize: false, // see http://forums.arcgis.com/threads/90825-Mobile-Sample-Fail  center: [-71.7, 42.35],  zoom: 8,  minZoom: 7,  logo: false,  slider: true,  sliderStyle: "small" }); arcgisUtils.createMap(webmapid, "mapDiv", { mapOptions: mapOptions }).then(function (response) {map = response.map;});
That should do what you're looking for.
ReneRubalcava
DavidKimball1
Great, it works! Thanks! Not sure how I missed that 🙂
