Can't use the same basemap from 2 URLs in the same browser
1410
04-03-2014 06:24 AM
RomainM_
Hello everyone,
I got a problem with CORS I can not solve.
I have two web applications on 2 separate IIS 7 servers (each has a URL). Both applications use the widget BasemapGallery.
If I want to run two applications in two different tabs of the same browser, the second loaded application is not able to open the arcgis online basemaps.
Indeed, I feel that the browser cache retains the header of the response to the first application and in particular the "Access-Control-Allow-Origin" property.
Here is an example:
1) I run a first application (hosted on a local IIS server) and ask for a basemap from arcgis online :
[ATTACH=CONFIG]32773[/ATTACH]
No problem.
2) I open a second tab with an arcgis-developpers sample (http://developers.arcgis.com/javascript/samples/widget_basemap/) and I ask for the same basemap.
[ATTACH=CONFIG]32774[/ATTACH]
Error, the header of the first response is retrieved from the cache and does not match. The request is blocked.
Tested Browsers: Firefox 28, Chrome 33
I hope to be clear, sorry for my broken English.
Anyone know how to fix this?
thank you,
Romain
