var sample = 'nicely formatted code';
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.1//EN" "http://www.w3.org/TR/xhtml11/DTD/xhtml11.dtd"> <html id="Html1" runat="server" xmlns="http://www.w3.org/1999/xhtml" dir="ltr"> <head id="Head1" runat="server"> <title>Web Mapping Application using Javascript API</title> <link href='https://community.esri.com/ArcGIS1/rest/ESRI.ArcGIS.Rest.css' rel='stylesheet' type='text/css' /> <meta http-equiv="Content-Type" content="text/html; charset=utf-8"/> <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/1.6/js/dojo/dijit/themes/tundra/tundra.css" /> <script type="text/javascript" src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=1.6"></script> <script type="text/javascript"> dojo.require("esri.map"); ///The script references the location of the ArcGIS Server JavaScript API files and the "map" package is referenced ///Note that the version number needs to be updated to the current version of the JavaScript API. var myMap; var myTiledMapServiceLayer; function init() { myMap = new esri.Map("mapDiv"); myTiledMapServiceLayer = new esri.layers.ArcGISTiledMapServiceLayer("http://din201009/ArcGIS1/rest/services/BaseMapping/MapServer"); myMap.addLayer(myTiledMapServiceLayer); ///layer is added to a map } dojo.addOnLoad(init); ///Onload event </script> <%-- For LTR. . . use these styles if dir="ltr" in html tag --%> <style type="text/css"> .appFloat1 {float: left;} .appFloat2 {float: right;} .appAlign1 {text-align: left;} .appAlign2 {text-align: right;} .combined1 {float: left; text-align: left;} .combined2 {float: right; text-align: right;} .mapPosition {left: 260px; visibility: visible;} .dockPosition {left: 0px; visibility: visible;} .dockToggleClass {visibility: visible;} .offview {top: 1600px;} </style> </head> <body style="margin: 0px 0px 0px 0px; background-color: white; width: 100%; font-family: Verdana; font-size:8pt; " > <div id="mapDiv" class="tundra" style="width:900px; height:600px; border:1px solid #000;"></div> <h4>Work flow:</h4> <ul> <li>Create a map.</li> <li>Add an ArcGISTiledMapServiceLayer.</li> </ul> <form id="form1" runat="server"> </form> <%-- <script language="javascript" type="text/javascript"> Sys.Application.add_init(startUp); </script> --%> </body> </html>
myTiledMapServiceLayer = new esri.layers.ArcGISDynamicMapServiceLayer
