Needed help on using own map service
1978
7
06-11-2010 12:22 AM
PRamachandran
I'm new to develope ArcGIS webmapping application using ArcGIS JAvascript APIs. I tried using the sample available at the resource site using Javascript API.
It worked sucessfully using the mapservice from ArcGisOnline as refered in the sample. Later I tried to use my own mapservice by creating a mapservice using the 'Publish Map service' option from the ArcGIS Manager.
I tried to replace the URL of the the newly published Mapservice with the existing one in the sample code as given below:
myTiledMapServiceLayer = new esri.layers.ArcGISTiledMapServiceLayer
           ("http://srvnamexyz/ArcGIS1/rest/services/BaseMapping/MapServer");/// Note: 'BaseMapping' is the name of the map service which is newly added
///("http://server.arcgisonline.com/ArcGIS/rest/services/ESRI_StreetMap_World_2D/MapServer");
            myMap.addLayer(myTiledMapServiceLayer); ///layer is added to a map
Then I tried to run the same application with this modification, but it resulted in displaying a blank map window.
Please kindly help me on how to use my own mapservice while developing web application using ArcGIS Javascript APIs, your help is appreciated.
Thanks in advance.
Ram
AdamPfister
Try to post a code sample that is as complete as possible using the CODE tags:
var sample = 'nicely formatted code';
if you type your map service URL with "?f=psjon" at the end into a browser: http://srvnamexyz/ArcGIS1/rest/services/BaseMapping/MapServer?f=psjon  do you get anything back?  if yes, what is it?  if an error, what is the error message?
PRamachandran
I get an error stating :-
Error
Unsupported format 'psjon'
Code: 400
Can you please kindly suggest further on this regards?
Ram
AdamPfister
that should be "pjson".  sorry about that.
PRamachandran
  "serviceDescription" : "",
  "mapName" : "Layers",
  "description" : "",
  "copyrightText" : "",
  "layers" : [
      "id" : 0,
      "name" : "UK_County_Boundaries",
      "parentLayerId" : -1,
      "defaultVisibility" : true,
      "subLayerIds" : null
  "spatialReference" : {
    "wkid" : 27700
  "singleFusedMapCache" : false,
  "initialExtent" : {
    "xmin" : -26869.8499046635,
    "ymin" : -55535.3854060575,
    "xmax" : 688396.489249775,
    "ymax" : 1281080.785195,
      "wkid" : 27700
  "fullExtent" : {
      "wkid" : 27700
  "units" : "esriMeters",
  "supportedImageFormatTypes" : "PNG24,PNG,JPG,DIB,TIFF,EMF,PS,PDF,GIF,SVG,SVGZ,AI",
  "documentInfo" : {
    "Title" : "BaseMapping",
    "Author" : "wall6694",
    "Comments" : "",
    "Subject" : "",
    "Category" : "",
    "Keywords" : ""
I get the above result on following your suggestion.
please kindly further guide me to resolve.
Ram
PRamachandran
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.1//EN" "http://www.w3.org/TR/xhtml11/DTD/xhtml11.dtd">
<html id="Html1" runat="server" xmlns="http://www.w3.org/1999/xhtml" dir="ltr">
<head id="Head1" runat="server">
    <title>Web Mapping Application using Javascript API</title>
 <link href='https://community.esri.com/ArcGIS1/rest/ESRI.ArcGIS.Rest.css' rel='stylesheet' type='text/css' />
    <meta http-equiv="Content-Type" content="text/html; charset=utf-8"/>
    <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/1.6/js/dojo/dijit/themes/tundra/tundra.css" />
    <script type="text/javascript" src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=1.6"></script>
    <script type="text/javascript">
        dojo.require("esri.map"); ///The script references the location of the ArcGIS Server JavaScript API files and the "map" package is referenced
                                  ///Note that the version number needs to be updated to the current version of the JavaScript API.
        var myMap;
        var myTiledMapServiceLayer;
        function init() {
            myMap = new esri.Map("mapDiv");
            myTiledMapServiceLayer = new esri.layers.ArcGISTiledMapServiceLayer("http://din201009/ArcGIS1/rest/services/BaseMapping/MapServer");
        dojo.addOnLoad(init); ///Onload event
    </script>
   <%--  For LTR. . . use these styles if dir="ltr" in html tag    --%>
   <style type="text/css">
        .appFloat1 {float: left;}
        .appFloat2 {float: right;}
        .appAlign1 {text-align: left;}
        .appAlign2 {text-align: right;}
        .combined1 {float: left; text-align: left;}
        .combined2 {float: right; text-align: right;}
        .mapPosition {left: 260px; visibility: visible;}
        .dockPosition {left: 0px; visibility: visible;}
        .dockToggleClass {visibility: visible;}
        .offview {top: 1600px;}
   </style>
</head>
<body style="margin: 0px 0px 0px 0px; background-color: white;  width: 100%; font-family: Verdana; font-size:8pt; " >
<div id="mapDiv" class="tundra" style="width:900px; height:600px; border:1px solid #000;"></div>
    <h4>Work flow:</h4>
 <ul>
 <li>Create a map.</li>
 <li>Add an ArcGISTiledMapServiceLayer.</li>
 </ul>
    <form id="form1" runat="server">
</form>
 <%--  <script language="javascript" type="text/javascript">
    Sys.Application.add_init(startUp);
    </script> --%>
</body>
</html>
I've pasted the full code with which I'm currently working for your reference.
I hope it would be helpful to you to correct me If I'm wrong.
AdamPfister
are you sure your layer you are trying to view is a Cached/Tiled layer?  it looks like it may be a dynamic layer from the json description you posted.
PRamachandran
Thanks for the hint. I changed :
to
myTiledMapServiceLayer = new esri.layers.ArcGISDynamicMapServiceLayer
Its working fine.
Thanks a lot! once gain 🙂
