need map to include all surrounding areas
1767
7
01-23-2012 05:48 AM
TonyRopson
I am attempting to have a map that highlights areas within a certain mile radius of a user selected point.  I am using a query task to return the geometry of those areas but I am having some trouble expanding the map to include all the areas returned by the query task.  Code snippets:
  function init() {             map = new esri.Map("mapDiv");             var layer = new esri.layers.ArcGISDynamicMapServiceLayer("http://lrs.co.columbia.wi.us/ArcGIS/rest/services/LRS/TaxParcels_Parcels/MapServer")             map.addLayer(layer);     for (j = 0; j < parnums.length; j++) {                 queryTask = new esri.tasks.QueryTask("http://lrs.co.columbia.wi.us/ArcGIS/rest/services/LRS/TaxParcels_Parcels/MapServer/1");                 query = new esri.tasks.Query();                 query.returnGeometry = true;                 query.text = parnums                 queryTask.execute(query, gettingResults);      function gettingResults(resultFeatures) {    featholding.push(resultFeatures); // this is the area the end user selected  var newExtent = esri.graphicsExtent(SearchPar[0].features)  //this is where I attempt to enclude the other areas that were returned by the  queryTask  for (j = 0; j < featholding.length; j++){                 var Uextent=esri.graphicsExtent(featholding.features)                 newExtent.union(Uextent)              }                               map.setExtent(newExtent.expand(1.1),true); }
I found union in the api docs but I am wondering if I am using it correctly
Thanks
derekswingley1
Ah, OK. So you're doing multiple queries and want to zoom to the extent of the features returned by all queries, correct?
If that's the case, i'd recommend using a deferredList so that you know when all the queries finish. We discussed this approach on the forums before...see this thread:  http://forums.arcgis.com/threads/37417
derekswingley1
You're on the right track. Instead of looping through all your features and unioning their extents, pass all your features to esri.graphicsExtent. Then set the map's extent, something like...
var newExtent = esri.graphicsExtent(resultFeatures);
map.setExtent(newExtent, true);
TonyRopson
I switched things up a bit and have this
function init() {
                 newExtent = esri.graphicsExtent(featholding.features);             }
however it appears that the map.setExtent is being set to the last piece of geometry in the array.  Is there are way to have the map include all the extents being passed in instead of the last one.
Also I tried
  newExtent=esri.graphicsExtent(resultFeatures);
but the map was not doing any focusing at all.
derekswingley1
In your gettingResults function, wouldn't you just want to use the extent of resultFeatures?
TonyRopson
yes I would but when I use
                newExtent = esri.graphicsExtent(resultFeatures.features)
All it is doing is showing the last piece of geometry that it was sent by the query task.  The query task is sending gettingResults about 8-10 separate pieces of geometry and I would like the map to be expanded to show them all.
   This is the last piece of the puzzle before this goes into production, so I very much appreciate the help everyone is giving me on this.
derekswingley1
Are you running more than one query task?
TonyRopson
one query task but it does get called many times
I will like to fit the results of the returned geometry into the viewer.
derekswingley1
