multiple select from Dojo grid
10125
20
01-28-2014 11:44 PM
ShaneCarey
Hey,
Has anybody used this example:
http://blogs.esri.com/esri/arcgis/2009/12/03/display-attributes-in-a-dojox-datagrid/
except changing the selectionMode to multiple
I have tried changing it but it will not work. I simple changed lines:
        <table dojotype="dojox.grid.DataGrid" jsid="grid" id="grid"
              selectionMode="none">
to
              selectionMode="multiple">
But nothing changes. Any row I click on the table, I need to highlight on the map.
ShaneCarey
Hey Ken,
Here is the link on jsbin
I have the services on an internal service here so I had to export them to you as a zipped file. Would you be able to put them on a server for you to test them in the code.
Wherever a service is being used, I have typed the shapefile Name in the code. When all is up and running it should look like this:
[ATTACH=CONFIG]31010[/ATTACH]
The shapefiles can be downloaded from here
