multiple select from Dojo grid
10170
20
01-28-2014 11:44 PM
ShaneCarey
Hey,
Has anybody used this example:
http://blogs.esri.com/esri/arcgis/2009/12/03/display-attributes-in-a-dojox-datagrid/
except changing the selectionMode to multiple
I have tried changing it but it will not work. I simple changed lines:
        <table dojotype="dojox.grid.DataGrid" jsid="grid" id="grid"
              selectionMode="none">
to
              selectionMode="multiple">
But nothing changes. Any row I click on the table, I need to highlight on the map.
ShaneCarey
Hey,
I got it. I had to add an extra layer for the states layer!!
Thanks very much for your help
KenBuja
MVP Esteemed Contributor
If you had only one layer in your service, you would have set this for the url
window.statesUrl = "http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Specialty/ESRI_StatesCitiesRivers_USA/MapServer/0";
I use Visual Studios for my development environment. You should also look at using Firebug and the browsers' Developer Tools (F12 key) for debugging.
ShaneCarey
Ok no worries, thanks. One quick question. How do I actually hide the layer on the map? I only want the lines to show that are selected.
Thanks again
KenBuja
This would work using FeatureLayers, using Definition Expressions. It would be a different workflow with ArcGISDynamicMapServiceLayers, since the graphics layer where you would show the results is separate.
ShaneCarey
By this I mean,
every row I select from the grid, thats the line that shows in the map.
Cheers
ShaneCarey
Hey,
I just published the service with no colour and that worked.
Thanks again for all your help
KenBuja
By this I mean,
Cheers
The example I created this morning does just that. You don't need to create a service with no colors.
ShaneCarey
Hey Ken,
I have many lines. Around 2000 flight lines (Tie lines and ordinary lines, Tie lines are perpendicular to ordinary), but only some are coming into my application and some are incorrectly displaying as Tie_lines when they should be lines.
Any idea why this is?
KenBuja
Can you put this in JSBin?
ShaneCarey
Will send first thing tomorrow, on Irish time here.
Cheers
